ᐅ Are there cost-effective methods for painting IKEA Platsa furniture?
Created on: 29 Jun 2016 08:37
Deogla2
Deogla2
29 Jun 2016 08:37
Hello everyone, I am currently working on a project to paint my IKEA Platsa furniture myself, but I am specifically looking for affordable methods that still deliver an attractive result. Are there any experiences in this forum with cost-effective painting techniques suitable for beginners? Important information would include recommended types of paint, surface preparation, and possibly alternatives to the usual spray paint or expensive paint systems. It would also be helpful to know how to avoid common problems such as unsightly drips, poor adhesion, or uneven coverage. Does anyone have tips or recommendations for products that are easy to find at a hardware store or inexpensive online? Thanks in advance for any advice!
labau
29 Jun 2016 09:47
My tip: first sand thoroughly, then apply a primer suitable for plastic. After that, use an affordable acrylic paint from a hardware store. Apply with a foam roller to prevent drips. Completely inexpensive and looks decent.
DUUS32
29 Jun 2016 11:09
I think it’s great that you’re taking this on, Deogla2! Especially with Platsa, the surface isn’t perfectly smooth, and the fun can quickly disappear if the right preparation isn’t done. I also had my doubts at first about whether painting could be cheaper than buying new, but with some self-discipline and patience, it really works well. You can definitely trust affordable spray paints if you apply many thin layers.
tolokau
29 Jun 2016 12:31
Hello Deogla2, to answer your question thoroughly, here is a brief guide:
- Preparation: The Platsa surface must be cleaned and sanded, ideally with 120- to 180-grit sandpaper. This ensures better adhesion.
- Primer: Always use an adhesion primer that is suitable for plastic. These typically cost between 5 and 10 Euros.
- Paint selection: Water-based acrylic paint is affordable and works well; there are also special furniture paints available.
- Application: I recommend a foam roller or a good quality brush. Spray paint is convenient but often more expensive and requires careful, even spraying distances.
- Drying time and intermediate sanding: Lightly sand after each coat to avoid unevenness. Patience is key here.
In summary: With sanding, priming, and good acrylic paint, you can achieve a durable result for little money. Keep in mind that cheap spray paints often provide poor coverage.
Renla47
29 Jun 2016 13:56
tolokau schrieb:
I recommend a foam roller or a high-quality brush. Spray paint is convenient but often more expensive, and it requires effort to maintain even spray distances.
I completely agree with this. Additionally, I would suggest painting the parts beforehand in a well-ventilated area. Especially with inexpensive paints, the odors can be quite bothersome. If you don’t need a perfect industrial finish, applying acrylic paint with a roller is an affordable and quick solution. The key is to carry out the work carefully.
Henry
30 Jun 2016 07:18
I understand your concerns, Deogla2. It’s easy to worry about damaging or ruining the furniture. What helped me was practicing first on an old piece and then working step by step with small amounts of paint. Affordable paint products can be surprisingly good if you apply them correctly. The most important things are patience and thorough preparation. That way, painting becomes enjoyable and you achieve a good result.
