ᐅ Are there IKEA PLATSA furniture pieces that can be assembled without screws?
Created on: 24 Jul 2016 10:37
ronklo
ronklo
24 Jul 2016 10:37
Hello everyone, I hope you can help me with this. I am planning to get some IKEA PLATSA furniture and I am looking for models or variations that do not require any screws – in other words, furniture that can be assembled without tools. Do such PLATSA furniture pieces even exist? So far, I have only seen the standard pieces that usually need screws and an Allen key to assemble. If yes, it would be helpful if you could tell me exactly which PLATSA items or systems can be assembled so easily and without screws. Many thanks in advance for your tips and advice!
Laukau5
24 Jul 2016 12:18
Hello, @ronklo! Your question about PLATSA furniture without screws is interesting and deserves a more detailed look. First of all: IKEA PLATSA is designed so that most components are modular and typically assembled using screws, dowels, and connectors to ensure stability. However, there are some individual parts or single components that use snap-fit or click systems, although these are more supplementary and not the norm. This means that complete furniture pieces from the PLATSA series without screws are very rare or nonexistent. The modular systems are meant to be flexible, so the connections need to be load-bearing—a simple snap-fit mechanism often can’t provide that. Still, IKEA generally has other furniture lines with options that require no tools, but as far as I know, that’s not the case with PLATSA. Could you clarify if you’re specifically looking for a certain type of furniture, such as cabinets, shelves, or combinations? That might help to look more specifically for alternatives or particular elements.
Renla47
24 Jul 2016 14:05
Hello everyone! To add some information from personal experience: IKEA primarily uses the so-called Minifix system and screws to securely connect the modules in PLATSA. It is true that some additional parts – such as shelves or interior fittings – can simply be hooked in or plugged in, but the main framework always requires screws.
ronklo schrieb:
I am planning to buy some IKEA PLATSA furniture and am looking for models or variations that can be assembled entirely without screws – in other words, that can be put together without any tools.
Unfortunately, there are no PLATSA furniture pieces that can be assembled completely without screws. If assembling without tools is important to you, the IKEA KALLAX system might be an alternative, as it is simply plugged together. However, in the PLATSA range this is really not the standard, because the furniture is designed for stability and flexibility when reconfiguring. Hope this helps!
lideo
25 Jul 2016 09:41
Hello, I assembled a PLATSA shelving unit myself. Screws are essential. There are no PLATSA furniture pieces completely without screws. You might be able to use individual snap-in components, but these are not stable load-bearing surfaces. My advice: get a good screwdriver, and the assembly will go quickly.
kaudi
25 Jul 2016 18:56
To add to this:
Renla47 schrieb:
Unfortunately, there are no PLATSA furniture pieces that can be assembled entirely without screws.
I completely agree. The PLATSA series is modular, flexible, and fairly sturdy – but it requires screws as connecting elements. Personally, I don’t find this problematic because the screw connections make the furniture robust. However, if you really want to assemble something without any screws, you should look at other series from IKEA or other manufacturers that focus specifically on snap-fit or interlocking connections. For a flexible and durable solution, PLATSA is simply not designed for that. If you have any questions about assembly or tools, I’m happy to help!
