ᐅ Are there Ikea PAX wardrobes available in non-standard sizes?
Created on: 27 Mar 2021 08:12
Pomopi
Hello everyone, I have a specific question regarding the Ikea PAX wardrobe system. Are the PAX wardrobes only available in the standard sizes, meaning the common widths, heights, and depths, or are there options to get PAX wardrobes in custom sizes that fall outside the standard range? I am particularly interested in whether Ikea itself offers custom-made units or if third-party suppliers need to be used to achieve PAX units with unusual widths or depths. I would appreciate a detailed explanation of the standard dimensions, as well as any information about flexibility and alternatives with the PAX system.
Dirkmin
27 Mar 2021 10:38
Regarding the question of size flexibility: Ikea offers the Pax system only in fixed standard dimensions. The standard widths are 50, 75, and 100 cm (20, 30, and 40 inches), heights are 201 and 236 cm (79 and 93 inches), and depths are 35 and 58 cm (14 and 23 inches). This follows the logistical and modular concept of the system. Custom-made options are not offered by Ikea. However, it is possible to combine multiple wardrobe units to fill unusual wall widths. Tailored adjustments are then carried out by carpenters or external manufacturers who produce similar systems according to customer specifications.
marmar50
27 Mar 2021 11:10
To be clear: Ikea does not sell PAX wardrobes with custom dimensions. All modules are standardized. Custom sizes? Only by building yourself or through an external supplier.
Pomopi
28 Mar 2021 07:39
I am asking quite specifically again because it is important for my case: Does Ikea offer any official customization options at all, such as partition walls, precise paneling, or modular extensions to accommodate atypical room heights or widths within the PAX system? Or is the only way to address these deviations by making independent cuts or adding extra components? The goal is to find the cleanest and most stable solution within the system frame.
sarlo
28 Mar 2021 08:05
Pomopi, officially Ikea does not offer dividers or modifications to change the basic dimensions of PAX units. For example, you can compensate for missing millimeters with trims or plinth feet to fit the wardrobe to the room. However, this does not alter the module sizes themselves but is more of a visual and functional adjustment. Additionally, there are wooden elements for covers or top panels that can help conceal the height and depth slightly. Ultimately, the modules retain the measurements of the standard version.
Nauman5
28 Mar 2021 08:34
Great summary, sarlo! I’ll add a little wink to that: Ikea PAX is like a standard suit for everyone – it doesn’t fit perfectly for everyone, but with a few tricks, it fits quite well. Cover panels, top panels, and feet are like the tailors that adjust it a bit to your space. Sometimes a bit of creativity helps to cleverly overcome the standard dimensions. 😉
meGreg
28 Mar 2021 10:12
Additionally, it is worth using the PAX planner tool on Ikea’s website. There, you can easily experiment with how different standard modules work together and how to design your desired layout with shelves and interior fittings. Although you are limited to the given dimensions, you can still plan a fairly customized wardrobe concept. For custom sizes, however, you will need to go to a carpenter.
