ᐅ Are there Ikea PAX wardrobes available with particularly deep shelves?
Created on: 23 Aug 2019 18:27
DANSU
DANSU
23 Aug 2019 18:27
I am currently planning my wardrobe using the IKEA PAX system and have a question I couldn’t find a clear answer to anywhere: Are there shelves or shelf boards for the IKEA PAX wardrobes that are significantly deeper than the standard cabinet depth? Specifically, I am looking for extra deep shelves because I want to store larger containers or bulkier items that don’t fit well on the usual shelves.
I understand that the PAX wardrobes come in different standard depths (e.g., 35 cm (14 inches), 58 cm (23 inches), 63 cm (25 inches)), but is it possible to get shelves that go beyond those depths? In other words, is there any accessory or special option for extra deep shelves beyond the typical sizes? Or are the shelves always designed to match the cabinet depth?
I would appreciate any tips or personal experiences.
Gilbert
23 Aug 2019 19:11
DANSU schrieb:
Are there shelves or shelf boards for IKEA PAX cabinets that are significantly deeper compared to the standard depth of the cabinets?
Interesting question, but honestly, I’m a bit skeptical: IKEA designs the PAX system based on modular standard dimensions. For logistical reasons, it’s quite unlikely that the shelves are significantly deeper than the cabinet depth.
You would then have to either retrofit or improvise, which somewhat contradicts the system’s principle. What speaks against simply choosing the deeper cabinets (e.g., 63 cm (25 inches)) if you need more depth? This way, you get almost the maximum storage capacity – expecting extra deep shelves would be, in my opinion, an unusual request.
Tevin
23 Aug 2019 20:05
Good evening!
Regarding your question: IKEA PAX cabinets are indeed available in different depths, typically 35 cm (14 inches), 58 cm (23 inches), and 63 cm (25 inches). The shelves and inserts are designed to match the cabinet depth, meaning a shelf for a 58 cm (23 inch) deep cabinet is approximately that deep.
As far as I know, there are no official shelves for PAX that extend significantly beyond the cabinet depth. The system is based on uniform modular components to ensure stability and secure installation.
If you specifically want a "particularly deep shelf," a custom solution or a different combination might be possible, but that would not be part of the standard PAX accessories.
Alternatively, you might consider whether combination elements like drawers or boxes could help make better use of the deeper space.
maureo
23 Aug 2019 20:37
As mentioned before: Shelf boards fit the cabinet depths and are not available in extra deep sizes. IKEA does not offer extra deep shelves for PAX.
naujon
24 Aug 2019 07:15
I’ll add a few details:
- The PAX series is modular, and the shelves are precisely matched to the chosen cabinet depth. This means a cabinet with a depth of 58 cm (23 inches) gets shelves that are slightly smaller, for example about 56.4 cm (22 inches) wide/deep.
- This is intentional so that the shelves fit securely into the designated notches and holes and can be held firmly in place.
- Deeper shelves would stick out, which would negatively affect installation, stability, and appearance.
If you really need more depth, I see two options:
- Choose a cabinet with a larger depth (for example, 63 cm (25 inches) from the start).
- Custom-made or DIY shelves that can be additionally secured, although this may affect warranty and stability.
In short: Officially, there are no “extra deep” shelves for PAX – they are always tied to the respective cabinet dimensions.
barsar
24 Aug 2019 08:42
I recently had the same issue. The shallowest version of the PAX is 63cm (25 inches), and the shelves are designed exactly for that. There are no extra deep shelves available.
If you need more space, you either have to increase the cabinet depth or build your own shelves.
