ᐅ Are there any folding rules or measuring sticks that are particularly useful when assembling IKEA PLATSA?
Created on: 3 May 2022 13:47
Doju8
Doju8
3 May 2022 13:47
I am about to assemble an IKEA Platsa system and was wondering if there are specific folding rulers that work particularly well for installing this system. I am especially concerned with measurements that need to be very precise, which are often important when assembling Platsa, such as accurate measuring in corners, exact lengths for the plastic profiles, or gaps.
I am mainly interested in which type of folding ruler has proven reliable for you, whether there are models with certain features, markings, or materials that can make the assembly easier.
Maybe you also have tips on how to avoid common measuring errors or at least recommend certain features that are beneficial when working with IKEA Platsa?
Looking forward to your experiences and advice!
rigau
3 May 2022 14:09
I recommend a folding rule with clear, easy-to-read markings and a sturdy construction made of fiberglass or metal. For PLATSA, I have often used simple 2-meter (6.5 feet) folding rulers because they are compact and easy to handle. It is important that the folding rule is not too flexible so you can measure accurately.
PRA64
3 May 2022 16:26
Hello Doju8,
your question is very relevant, as installing IKEA PLATSA requires precise measurements due to the different profiles and corner solutions involved.
Here are some tips and advice on using folding rulers for this type of installation:
- Recommendation: It’s best to use a high-quality wooden or fiberglass folding ruler with clear millimeter markings. With PLATSA, accuracy is essential because even small deviations can cause fitting issues.
- Features: Some folding rulers have measuring edges with anti-slip coating, which is especially helpful on smooth surfaces.
- Special cases: For measuring corner joints or gaps, consider folding rulers with joints or modular connected segments. These are a bit more expensive but allow flexible adjustment to irregular angles.
- Avoiding measurement errors: It’s better to measure twice and always hold the folding ruler straight. Sometimes additional tools like angle finders or small spirit levels can be helpful.
Summary: A standard, sturdy folding ruler with clear millimeter scales is usually sufficient; those who want more convenience can choose specialized models with joints or anti-slip coatings. Careful measuring and proper handling are particularly important with IKEA PLATSA.
I hope this helps you!
GiRoyce
4 May 2022 09:14
PRA64 schrieb:
There are folding rulers with measuring edges that have an anti-slip coating, which is especially helpful on smooth surfaces.
I can fully confirm that. Especially with the PLATSA system, which involves many plastic profiles, such an anti-slip coating prevents unwanted slipping while measuring.
Alternatively, I have also used a small, quite affordable metal ruler. It is shorter, but its low flexibility and sharp edges help achieve precise measurements. It also rests well against edges.
rigau schrieb:
For PLATSA, I often used simple 2-meter (6.5 feet) folding rulers because they are compact and easy to handle.
I agree. For furniture construction in general and PLATSA in particular, longer tape measures are practical, but the classic 2-meter (6.5 feet) folding ruler is more manageable and often better suited for tight corners.
When working with IKEA PLATSA, it’s always useful to have a spirit level or a small angle tool on hand to detect any deviations in depth or height early on.
Overall, I recommend a sturdy, easy-to-read folding ruler with an anti-slip coating or a metal ruler for precise measurements, along with some small measuring tools for verification.
Giagau
5 May 2022 11:38
Regarding the question of whether there are special folding rules that are particularly suitable for assembling IKEA PLATSA, I would like to add the following:
The requirements for PLATSA often involve precise adjustment of wall dimensions and profiles – especially in room corners or when placing modules flush side by side. In this context, the following features are useful:
- A folding rule with finely engraved or printed millimeter scales that remain easily readable even in low light.
- A sturdy construction made of fiberglass or reinforced plastic that does not twist.
- Hinged or flexibly segmented folding rules are rather uncommon; in such cases, I would recommend using a second tool like a small square.
- For those who still prefer folding mechanisms, high manufacturing quality is important to prevent inaccuracies caused by play.
My tip: a solid 2-meter (6.5 feet) wooden folding rule or a metal measuring stick with clearly readable scales is often the best choice – this combination offers precision and convenience, especially when measuring carefully and systematically. For special challenges like corners, supplementary tools such as small squares are advisable and should be planned for accordingly.
This approach helps avoid measurement errors and significantly simplifies the assembly in the end.
