ᐅ Are there soft-close door hinges available as replacement parts for Kallax units?
Created on: 20 Mar 2023 17:27
Munureo
Munureo
20 Mar 2023 17:27
I have a specific question: Are there door hinges with a soft-close feature available as replacement parts for IKEA’s Kallax shelving unit?
I have a Kallax with doors, and one of the hinge dampers is broken, so the door no longer closes softly. I’m looking for suitable replacement parts, preferably with soft-close functionality, as I find it very convenient. Unfortunately, I couldn’t find soft-close replacement hinges at IKEA, only standard hinges.
Are there compatible hinges from third-party suppliers that can be used as replacement parts for the Kallax? It’s important that installation doesn’t require extensive modifications, meaning matching screw holes and standard dimensions.
I look forward to your experiences and tips, thanks in advance!
SauDietmar
20 Mar 2023 18:03
Hello Munureo,
Regarding your question: "Are there soft-close door hinges for Kallax available as replacement parts?" Here is a brief introduction and solution:
1. Background: The Kallax shelf typically uses basic cabinet door hinges from Ikea, which do not have a soft-close function. These are usually standard cup hinges with a 35mm (1.4 inch) drilling diameter.
2. Standard dimensions: It is important that replacement hinges have the same hole spacing and the same diameter (35mm (1.4 inch) drilling), otherwise they will not fit properly.
3. Soft-close replacements: There are third-party manufacturers offering cup hinges with soft-close functionality, for example Blum or Hettich. These are generally universal but may require minor adjustments.
4. Installation notes:
- Check measurements carefully (drill hole position, door thickness).
- Possibly use a new drill hole set.
- Soft-close hinges usually cost a bit more but provide better convenience.
5. Tip: Stores specializing in furniture accessories or Ikea replacement parts often help, but the easiest way is to search for "35mm cup hinges with soft-close."
Conclusion:
Such hinges do exist and are compatible, but careful measurement is necessary. For a simple upgrade, purchasing BLUMOTION or similar products is recommended.
If you like, I can look up some suppliers for you.
Dietmar
Munureo
21 Mar 2023 09:46
SauDietmar schrieb:
Soft-close hinges usually cost a bit more but provide better comfort.
Thanks a lot for the detailed response, Dietmar!
Indeed, the comfort of a soft-close hinge is my goal, but I also find it important to keep the installation as straightforward as possible.
Do you or anyone else perhaps have specific model recommendations for hinges from Blum or Hettich that would really fit Kallax doors without much hassle?
Also: Is converting standard Kallax hinges to soft-close reversible in case someone wants to switch back to the original hardware later? Is there a risk of damaging the wood or needing to drill new holes?
Thanks for any advice!
tra_nina
21 Mar 2023 12:31
Munureo schrieb:
Is it possible to reverse the conversion of standard Kallax hinges to soft-close if you want the original replacement hinges again later?
Regarding the question of reversibility: In principle, replacing standard single hinges with soft-close hinges on Kallax shelves is technically feasible, but it requires that the drill holes match exactly.
IKEA typically uses cup hinges with a 35mm (1.38 inches) drill hole for Kallax doors. Soft-close hinges from brands like Blum or Hettich have the same basic diameter. However, the screw positions can vary slightly, which may cause issues if the hole spacing differs.
Recommendation:
- Measure the existing hinge carefully (hole spacing and position) before purchasing.
- Compare these measurements precisely with the specifications of the desired soft-close hinge.
If the hole positions do not align exactly, new holes will need to be drilled. This always carries the risk of damaging the wood or leaving visible marks.
An alternative is to use a retrofit soft-close cap that some manufacturers offer. These clip onto the existing hinge and provide a soft-close function without replacing the hinges.
Summary:
The conversion is possible but may not be entirely free from visible changes. If you want to preserve the original appearance and wood, you should carefully check the drill holes or consider a retrofit soft-close cap.
parnar
21 Mar 2023 16:58
tra_nina schrieb:
One alternative is to retrofit an existing hinge with a soft-close cap
That’s brilliant!
I have a Kallax with doors myself and installed these caps – they work great!
Installation only takes a few minutes, no new holes, no drilling, and now the doors close softly and quietly.
If anyone is interested: these caps are really affordable and easy to find online.
This way you get soft-close convenience without altering the furniture. A great lifehack for anyone with Kallax doors! 🙂
Munureo
22 Mar 2023 08:17
parnar schrieb:
The installation takes only a few minutes, no new holes, no drilling, and the doors now close very softly and quietly.
Thank you for the tip! That really sounds perfect.
Does anyone know specific manufacturers or suppliers for these soft-close caps?
And do the dampers hold up well over time, or do they wear out relatively quickly? I would prefer a solution with good durability.
I’m curious to hear about your experiences with their lifespan.
