ᐅ Are there any assembly tips to speed up building the IKEA Hemnes furniture?
Created on: 25 Feb 2021 10:13
MANKU
Hello everyone, I am currently about to assemble my new IKEA Hemnes wardrobe and was wondering if there are any assembly tips to make the process faster and, above all, more efficient?
I have already looked at the instructions, but some steps seem a bit awkward. Especially inserting the screws and wooden dowels doesn’t always go smoothly for me.
Are there any specific tools, techniques, or aids I can use to speed up the assembly without compromising stability or the final result?
Maybe some of you have experience with special methods or procedures I should keep in mind? I’d appreciate any advice!
PECLARISSA
25 Feb 2021 12:44
One more little tip with a bit of charm: before inserting the wooden dowels, you can lightly dampen them or brush on a small drop of oil – this makes insertion much smoother!
Also, it often helps to accompany the individual work steps with some music; it motivates and makes problems easier to handle. 😉
Good luck with the assembly!
RETRAVIS
26 Feb 2021 09:12
lorena schrieb:
What does your current tool setup look like? Are you using a cordless drill or just screwdrivers?
This is a crucial point. If you are only using a manual screwdriver, definitely consider getting an adjustable cordless drill. It speeds up the process significantly and reduces fatigue.
The preparation of parts should not be underestimated either, as good organization actually saves more time than you might initially expect.
nofomu
26 Feb 2021 09:34
Rub the dowels with a little soapy water; this makes them much easier to insert. First, screw the screws in by hand until snug, then tighten them all again afterwards. This way, you can better check the fit.
GU-LAU60
27 Feb 2021 08:52
Always unpack and sort all parts first. Keep screws separate and easily accessible so you don’t have to search for them. It’s better to assemble with two people, especially when handling large components.
lorena
27 Feb 2021 10:17
Layla schrieb:
Are there any specific areas that seem particularly complicated to you?
That is a very important question because some assembly steps require extra attention. For example, attaching the side panels to the carcass is often done with imprecise alignment. If there are issues here, it can be helpful to initially screw the parts together loosely and check the alignment again with a spirit level before fully tightening the screws.
Also remember to install the back panels, which are often underestimated. If these are not fitted precisely, it can also lead to instability.
How is it going for you so far? Are there specific steps where you are stuck or where the instructions seem unclear?
