ᐅ Are there any tips for transporting Ikea Platsa furniture efficiently?
Created on: 13 Dec 2016 09:17
AscaniusleA
Ascaniusle13 Dec 2016 09:17Hello everyone,
I am currently facing the challenge of transporting several Ikea Platsa furniture units and was wondering if anyone has tips on how to prepare them most effectively and securely for transport, as well as how to handle the transport itself.
Specifically, I am interested in whether it is better to disassemble the modules completely or if some parts can be left partially assembled. It would also be helpful to know the best way to secure the pieces to prevent any damage—especially since the back panels and doors seem quite fragile.
Are there any recommendations regarding the vehicle size or the types of packing materials to use? I look forward to your experiences and tips that can make this process easier!
JEREMIAH3813 Dec 2016 10:35Ascaniusle schrieb:
Are there any recommendations regarding vehicle size or which packing materials to use?Hi! I completely understand feeling unsure at first—Platsa modules are quite heavy and bulky. From my experience, it’s definitely worth disassembling the furniture into as many individual parts as possible. The back panels are really delicate, so additional protection with cardboard or blankets is advisable.
As for the vehicle: a large station wagon or small van is ideal, as it allows you to carry longer pieces more easily. I once didn’t have enough space and had to improvise, which was quite stressful. Don’t put too much pressure on yourself—safety comes first.
Regarding securing the load: ratchet straps and non-slip blankets are invaluable. If you have some moving blankets, definitely use them to prevent scratches!
I would always disassemble Platsa. The individual parts are easier to carry and can be better protected. Pack back panels and doors in sturdy boxes or wrap them with blankets. Vehicle: small van or station wagon with sufficient length. Use ratchet straps to secure everything so nothing shifts.
V
valerie-tr14 Dec 2016 07:53Hello,
I would like to add that during the transport of the Platsa series, some technical details are often overlooked, which are crucial for a smooth process. While it is generally possible to transport the modules partially assembled, the risk of damage is significantly higher, as the furniture is not designed for transport in an assembled state.
My advice: When packing the modules disassembled, pay close attention to how the back panels are removed. These are typically made of particleboard and are very sensitive to bending and moisture. It is best to store them flat – not standing on their edge, as this can cause breakage. You can wrap the back panels with protective film or place them between cardboard sheets.
For transport, ratchet straps that are evenly tensioned are suitable to avoid pressure marks. If using blankets or foam padding, make sure the padding is not too thick, otherwise the parts may no longer fit optimally in the vehicle.
Regarding the vehicle: A van with a loading area of at least 130 cm (51 inches) in length and at least 100 cm (39 inches) in width is recommended. The loading height should not be less than approximately 90 cm (35 inches) to allow for space-efficient stacking of the modules. A practical tip: When loading the modules, place the heavier ones at the bottom and the lighter ones on top to make the load more stable.
Personally, I have had good experiences carrying all screws and small parts in well-labeled bags to simplify later reassembly. Missing parts can easily double the time required.
What I would still like to know: How many modules do you want to transport, and what kind of vehicle will you be using? Then the advice can be tailored even more specifically.
Ascaniusle14 Dec 2016 12:11valerie-tr schrieb:
What I would like to know is: How many modules do you plan to transport and in which vehicle will you do that?Thank you for the detailed response! I have a total of four different Platsa modules that I need to transport. The vehicle is a mid-sized station wagon with a cargo area of about 110 cm (43 inches) wide, 125 cm (49 inches) long, and approximately 85 cm (33 inches) high. I can extend the cargo space by folding down the rear seat.
So far, I haven’t started disassembling the modules because I was unsure about the most efficient order and approach. It would be great if you could give me some tips on the best way to proceed to avoid problems with damaged furniture or lost small parts.
Ascaniusle schrieb:
I haven’t started disassembling the modules yet because I wasn’t sure what the most efficient order and method would be.I understand that well; the disassembly process can seem complicated without instructions. Here is a proven approach:
- First, remove the doors: these usually have special hinges that are easy to detach, which helps prevent damage to the doors.
- Next, remove the back panels carefully by loosening nails or staples. This is easiest with a flat screwdriver or a flush-cut saw blade.
- Then take apart the larger side panels and shelves; I recommend organizing the screws systematically by putting them in labeled bags.
Important: Mark the modules and their sides so you know exactly where everything goes during reassembly. Avoid breaking down the furniture into all individual parts if you plan to rebuild soon—sometimes it’s better to keep certain module elements together if they fit well.
Hope this helps you stay organized! If you have any questions, just ask.
