I am planning to assemble an Ikea Hemnes bed myself, but I have heard from several people that putting this particular piece of furniture together is not always very straightforward and can involve some difficulties.
My question is therefore: Are there any specific tips or best practices you would recommend to ensure the Ikea Hemnes bed is assembled as securely and stably as possible?
I am especially interested in advice on how to avoid common mistakes, which tools are helpful, and if there are any important points to pay attention to so that the bed is durable and sturdy.
I look forward to your experiences and advice!
Hey Dionsar!
Awesome that you’re tackling the Hemnes bed – truly a classic from Ikea! 🎉 I can definitely share a few tips that really helped me back then:
- Make sure to give yourself plenty of time and assemble it calmly, don’t rush!
- Find a large, clean area so you don’t lose any parts
- Start by screwing all bolts in loosely, align everything, then tighten everything properly at the end
- A cordless drill with adjustable torque makes the job much easier
- Before the first night’s sleep, check that the bed is stable – if it wobbles, tighten everything again
And don’t worry if you get stuck at some point: sticking with it is worth it! This piece will last you forever 👌 Good luck, and let us know how it went!
vinpau schrieb:
First, loosely screw in all screws, align everything, and then tighten them properly at the endThis is truly a key point!
Additionally, I would like to add that when assembling the Hemnes bed, you should pay attention to the order of assembly. Ikea explains it quite well in the instructions, but I strongly recommend fitting the parts together without tools first to ensure everything fits correctly.
It also helps to carefully check the existing drill holes and connecting elements to avoid placing any screws in the wrong spot—especially on the headboard or side rails.
Tools: An Allen key is usually included in the package, but a small Phillips screwdriver can also be very useful.
Once the bed is assembled, it is important to place it on a level surface to avoid unnecessary pressure on specific areas.
Do you already have all the parts and tools ready, or are you still just starting out?
Hello Dionsar,
I would like to provide a more detailed explanation of the construction of the Hemnes bed, as the topic is somewhat more complex than it appears at first glance.
First, it is important to create a stable foundation: this means the floor must be level to ensure even load distribution. Unevenness can lead to material fatigue over time.
When assembling, careful handling of the connector fittings is crucial. Ikea often uses so-called dowels and cam lock systems, where precise angles must be maintained to guarantee stability.
A common pitfall is overtightening the screws too early during assembly, which can damage the wood or make the joints unstable.
I recommend the following steps:
- Sort all parts according to the instructions and check that all components are present and undamaged
- Before assembly, lightly sand all connection points with fine sandpaper, especially edges and drill holes
- Without fully tightening, temporarily fit all parts together to test stability and alignment
- Then gradually tighten screws and fittings; do not apply full torque immediately
- If the instructions leave room for it, use wood glue to strengthen dowel joints—but use sparingly
These careful steps help prevent problems later, such as material failure or misalignment.
I hope this helps you. I am also curious: are you planning to assemble the bed alone or with assistance? Some steps can be more difficult when working solo due to the size of the components.
