ᐅ Are there any tips for installing Ikea PLATSA with several helpers?
Created on: 30 May 2021 08:27
sulaglaHello everyone, I am planning to assemble several Ikea Platsa modules in our living room. Since these modules are quite large and sometimes heavy, I don’t want to do the assembly alone but with several helpers. Does anyone have experience with the best way to organize the assembly of PLATSA when multiple people are working together? Are there any special tips for dividing the tasks, preparing the assembly steps, or tools that make the process easier? I would really appreciate it if you could share your experiences, tricks, or pitfalls, especially regarding coordination among several helpers. Thanks in advance!
sulagla schrieb:
Since these modules are quite large and partly heavy, I don’t want to assemble them alone but rather with several helpers.Great plan, because doing it alone can quickly turn into a real workout! 😅
My advice would be: Make a clear plan before starting assembly about who will do what. For example, one person can sort and prepare the individual parts while another assembles the main modules. Especially with PLATSA, it makes sense if one person holds the large parts and another fastens them – otherwise, parts will start sliding around immediately.
Also: Stay relaxed! When you screw together as a team, most things go easier, even if something doesn’t fit perfectly at first. A pro tip (even if it sounds obvious) – don’t forget a spirit level and a cordless drill with a good battery. That makes the job go smoothly. Good luck and have fun building your furniture! 😉
sulagla schrieb:
Are there any specific tips for dividing tasks, preparing construction phases, or tools that make the process easier?I’m happy to provide a structured overview of how I assembled several PLATSA modules with helpers:
- Preparation: Sort all parts in advance according to the instructions, ideally placing them individually on tables or assembly surfaces
- Task allocation: Assign 1-2 helpers to hold large parts, 1 helper to screw with a cordless drill, and 1 helper to align and check with a spirit level
- Step-by-step assembly: Assemble large modules first without doors, then mount the doors separately
- Communication: Clear agreements before each step about who holds and who screws
- Tools: Cordless drill (preferably with longer bits), spirit level, possibly a small hammer and a Torx screwdriver (for fine adjustments)
Common mistakes include pushing the modules together prematurely without precise alignment and neglecting to check for levelness. I recommend briefly checking after assembling each part before continuing. This will save you a lot of rework.
meGreg schrieb:
A tip from a pro (even if it sounds obvious) – don’t forget a spirit level and a cordless drill with a good battery.Spirit levels and cordless drills are certainly standard, but I’d like to emphasize the importance of assembly sequence. With PLATSA modules, expansion is often modular, but without the correct order, precise connections can become difficult, especially when multiple people are working.
Also, it’s advisable to carefully check the floor and wall conditions before installation. This is particularly important if you plan to attach several modules to walls, as irregularities can have a significant impact. A discussion about the type of anchors and screws is also crucial to avoid problems later on.
Furthermore, I would recommend that having too many helpers does not necessarily simplify teamwork. It’s better to work with three well-coordinated people than five who get in each other’s way. Efficiency comes from clear roles, not just from having more hands.
Sinan-meo1 Jun 2021 07:56KUDAISY schrieb:
Typical mistakes include rushing to push the modules together without precise alignment and neglecting to check the levelness.This is definitely a point I can agree with. A properly secured, level base is essential to avoid adjustments later on.
In my experience, it also helps to clean the mounting surfaces beforehand – dust or small chips under the feet can affect the levelness.
Additionally, when working with several helpers, it’s important to include short communication phases between assembly steps so everyone knows when to start or pause.
It’s also practical to have cloths or gloves ready to prevent scratches on surfaces. This sounds trivial but is often forgotten and can be frustrating in the long run.
