ᐅ Are there any recommended guides for fitting soft-close mechanisms to Ikea Besta doors?
Created on: 14 Dec 2023 08:37
Dojeffery
I am planning to upgrade my Ikea Besta cabinet units with soft-close doors. Since the original doors usually don’t come with soft-close, I’m looking for recommendations for good guides or practical solutions to retrofit the doors with a soft-close feature. I’m especially interested in options that don’t require major modifications or special tools and are also durable.
Do you have experience with specific soft-close hinge inserts or adapter solutions for Besta?
I would really appreciate tips, illustrated step-by-step instructions, or advice on issues and common mistakes to avoid.
Thanks in advance!
koduga
15 Dec 2023 09:14
I was also able to retrofit my Besta doors with soft-close hinges. At first, I was a bit hesitant because I didn’t want to make major changes to the furniture.
tra_nina schrieb:
Direct installation without drilling is often possible if you use the so-called clip-on soft-close mechanisms, which can simply be attached to the existing hinges.
I can definitely confirm that. For me, it was important to keep the original as unchanged as possible while increasing comfort. The first attempt worked really well, and the effort was quite manageable.
If you’re unsure, just give it a try – you quickly learn how it fits best. The door now closes softly and quietly, which is appreciated by everyone in the family.
warrenka57
15 Dec 2023 10:52
Although there are some simple solutions, when retrofitting, you should ensure that the soft-close mechanism is not set too strongly. Otherwise, I maintain my impression that the furniture suffers as a result.
vinlen schrieb:
Cheap models tend to lose functionality quickly or fail to properly slow the door.
That is an important point. It’s better to invest in quality and, if possible, test on a single sample piece of furniture. In forums, I have read that some users also rely on compatible original Ikea soft-close fittings, which are more expensive but fit perfectly and are very durable.
nojaus
15 Dec 2023 11:17
In my experience, retrofitting Softclose on Ikea Besta doors is one of the most popular upgrades for added convenience. To find a really good guide, make sure it matches the specific Softclose model with your door type.
- Use a Softclose system that is explicitly compatible with Besta doors
- Check the installation method before purchase (clip-on vs. screws)
- Test the function before fully tightening the screws
This way, you can avoid misalignment after installation or malfunction of the Softclose mechanism.
