ᐅ Are there any practical DIY ideas for repairing damaged IKEA Brimnes parts?
Created on: 27 Jan 2021 19:03
Muleonard
Hello everyone, I recently acquired some IKEA Brimnes furniture pieces that unfortunately have minor damages—mainly chipped edges, scratches, and a slightly warped drawer. Before ordering replacement parts or considering new furniture, I’m wondering if there are any practical DIY methods to restore or repair these damaged items myself.
I’m particularly interested in approaches that help restore the appearance as close to the original as possible, without too much effort or expensive materials. Has anyone had experience with sustainable and visually appealing repairs for Brimnes furniture? What materials are suitable, and what should be considered when gluing edges, sanding surfaces, or filling in damaged areas?
I look forward to your tips and opinions!
tolokau
28 Jan 2021 15:04
I would like to add to the previous tips with a brief DIY guide for repairing Brimnes furniture, which is often made from coated particleboard:
- Assessment: Check if the piece is repairable (no structural deformations)
- Cleaning: Degrease all surfaces and remove any dirt
- Scratches & small chips: Use repair filler specifically designed for plastic or wood-based panels. There are pastes available that can be sanded smooth after curing.
- Edges: Self-adhesive edge banding (matching Brimnes colors) can often restore both the appearance and durability of chipped edges.
- Warped drawers: If they have swollen or warped due to moisture, gentle application of heat combined with weighting may help
- Surface touch-up: Light sanding, followed by retouching with a color-matched touch-up pen or a thin coat of paint
Important: Patience and planning are key! Rushed repairs usually result in visible signs.
Finally, it is best to care for the furniture only with mild cleaning agents to prevent damage.
FELOTAU
28 Jan 2021 18:36
I believe this topic resonates with many who prefer not to simply throw away their furniture.
Muleonard schrieb:
Which materials are suitable, and what should you pay attention to when gluing edges, sanding surfaces, or making repairs?
I have had good experiences using waterproof wood glue for minor edge repairs, but be careful: the glue needs to be spread evenly and thoroughly, otherwise there can be warping or unsightly glue marks after drying.
Additionally, I recommend using fine sandpaper (grit 240 or higher) after sanding and filling, and then sealing the surface with clearcoat or, for example, furniture wax – this protects the surface from further moisture penetration.
Sometimes you can really save a lot this way, but you shouldn’t expect it to look brand new afterward. In many cases, however, it is visually sufficient.
Karsten45
29 Jan 2021 10:52
I have to say, I’m a big fan of DIY repairs, especially with IKEA furniture like Brimnes. The charm is really that you can achieve a lot with relatively little effort.
One thing I always recommend is taking a playful approach – don’t take everything too seriously. My tips:
- Scratches can be surprisingly well concealed using wax crayons in matching colors.
- For chipped corners, you can even cut small wooden pieces and glue them on, then sand and paint as needed.
- If something fits, you might get creative by covering panels with fabric or cork – turning the damage into a real feature!
This is where your personal touch comes into play. You don’t have to keep everything original; you can also enjoy making small creative changes. 😉
