ᐅ Are there any practical DIY ideas for repairing damaged IKEA Brimnes parts?
Created on: 27 Jan 2021 19:03
Muleonard
Muleonard
27 Jan 2021 19:03
Hello everyone, I recently acquired some IKEA Brimnes furniture pieces that unfortunately have minor damages—mainly chipped edges, scratches, and a slightly warped drawer. Before ordering replacement parts or considering new furniture, I’m wondering if there are any practical DIY methods to restore or repair these damaged items myself.
I’m particularly interested in approaches that help restore the appearance as close to the original as possible, without too much effort or expensive materials. Has anyone had experience with sustainable and visually appealing repairs for Brimnes furniture? What materials are suitable, and what should be considered when gluing edges, sanding surfaces, or filling in damaged areas?
I look forward to your tips and opinions!
TARAON
27 Jan 2021 19:27
Hey, first of all, respect for not just throwing everything away! 😊 I once repaired a Brimnes bed myself – more out of necessity. Here are my tips:
- For small scratches: IKEA has simple repair markers in matching colors that really work wonders.
- Chipped edges can be easily filled with wood filler and then gently sanded down.
- For warped parts: Sometimes lightly dampening and applying weight helps to restore the shape.
Nothing too complicated, but this is often enough for everyday use. The main thing is to keep the DIY spirit alive – and save yourself some expensive replacements.
Sometimes you just have to improvise a bit, but that can be fun too!
BAUEVA
27 Jan 2021 20:15
TARAON schrieb:
Chipped edges can be well filled with wood filler and then carefully sanded down.
However, I would like to approach this critically: wood filler is a common method, but for IKEA furniture with coated chipboard panels, I would only use it to a limited extent. The material and the surface layers are special, and filler can often create unattractive transitions at the edges that become noticeable without further treatment.
Instead, I would recommend using self-adhesive veneer strips matching the decor or repairing edge banding, if possible. Additionally, one should consider whether the piece of furniture justifies the effort or if ordering a specific replacement part from IKEA might be more efficient and sustainable.
In the end, DIY is usually only worthwhile for minor cosmetic flaws.
PEDRO40
27 Jan 2021 21:43
I can understand how frustrating such minor damage to furniture can be, especially when you are attached to it or don’t want to spend money on replacements all the time.
Muleonard schrieb:
I am mainly interested in methods that restore the appearance as close to the original as possible, without too much effort or expensive materials.
That’s why I think the suggestion to use repair and touch-up pens is very good. I once had a similar case and achieved surprisingly good results with some patience and masking tape. The important thing is really to take your time and avoid rushing.
I would also recommend lightly sanding the repaired areas afterwards with fine steel wool or very fine sandpaper, then applying a suitable sealant or clear coat to improve durability.
nanidra
28 Jan 2021 07:59
Let’s be honest, aren’t we often too quick to start repairing before considering the obvious? Brimnes is an inexpensive piece of furniture – so why spend a lot of time and materials on repairs that at best result in ugly patchwork?
BAUEVA schrieb:
In the end, DIY is usually only worthwhile for minor cosmetic issues.
Exactly. And even then, I wonder how practical it really is. I mean, if the cabinet is warped, it’s almost irreparable without a complete replacement. Most DIY solutions might look okay, but they don’t provide long-term durability.
When I see a piece of furniture with serious damage, I prefer to consider buying new or at least replacing the certified spare parts. Sustainability doesn’t mean excessive improvisation; it means doing the right thing and not wasting time on unstable compromises.
JONKO
28 Jan 2021 11:12
nanidra schrieb:
When I see a piece of furniture with serious damage, I prefer to consider buying new or at least replacing the inspected spare parts.
I understand why someone might think about buying new, but financial constraints or environmental considerations don’t always allow that. I personally repaired a damaged Brimnes shelf. Here is what I did:
- Filled chipped areas with white wood filler
- Sanded it smoothly after drying
- Painted over it with acrylic paint from a hardware store
- Finally, applied a clear varnish for protection
The shelf has now lasted for 2 years without the damage becoming visible again. Sometimes it’s not perfect, but with patience and good materials, furniture can definitely be saved. Especially when memories are attached to it, in my opinion, the effort is worth it.
