I am new to the forum. We are at the beginning and in the planning phase for a single-family house. We want to accept an offer where the house is pre-designed and the plot is already included. A small development with 21 houses is being built.
The developer is called "Allegro-Haus." Has anyone had any experience with this company?
What should you definitely pay attention to when signing the contract?
I am grateful for any good advice!
Regards
Regards
Condor schrieb:
Should the roof be insulated? The exterior thermal insulation composite system (ETICS) is sufficient. On the room side, install a vapor barrier!Condor schrieb:
...Can a cold loft be used as storage space? Yes, just board over the insulation of the ETICS. Under no circumstances lay old linoleum or similar materials on it; it must remain vapor-permeable towards the attic! Best regards
€uro schrieb:
The OGD is sufficient. On the room side, a vapor barrier!Thanks for the tip. How exactly does a vapor barrier work, and how is it constructed in building terms?
Is it possible to cover the ceiling with polystyrene (styrofoam) boards on top of it, or should a more breathable type of cladding be used?
BratacDD schrieb:
What information do you have regarding the delay in this area?As far as I know, the advertising board has been standing there for quite some time, I would say at least 3 to 4 years. We were interested in this location back then as well, but decided against it after getting in touch with Allegro-Haus. The best thing is to contact Allegro directly.
Regards and good luck
