ᐅ Allegro-Haus Ltd. Experiences
Created on: 3 May 2012 11:14
Condor
I am new to the forum. We are at the beginning and in the planning phase for a single-family house. We want to accept an offer where the house is pre-designed and the plot is already included. A small development with 21 houses is being built.
The developer is called "Allegro-Haus." Has anyone had any experience with this company?
What should you definitely pay attention to when signing the contract?
I am grateful for any good advice!
Regards
jaeger29 May 2017 00:44
Der Da schrieb:
You need to make sure that on the ventilated roof you don’t install OSB boards (use tongue-and-groove boards instead), and also avoid installing any flooring around the edges for about 10 cm (4 inches). This way, it stays dry up there and you can use the ventilated roof as storage. But only for items that are not affected by heat or cold. There are special storage bags for that...
We have planned a concrete ceiling for the upper floor to avoid the ring beam and some other elements. Also, the insulation, which will be done by ourselves, is easier this way.
Because of the concrete ceiling, no vapor barrier is needed. So, insulation goes directly on the concrete, followed by chipboard panels on top. As you already mentioned, OSB boards are not recommended because their vapor diffusion resistance (sd-value) is even higher than that of chipboard panels. Now that I’ve read your answer, I wanted to ask if tongue-and-groove boards would even make sense in my case. Probably not, since I have to install them as a floating floor. I would still appreciate a brief reply.
29 May 2017 10:06
jaeger schrieb:
...I would still appreciate a brief reply.
The thread is 5 (five) years old, and the user last posted 3 (three) years ago...
Best regards in brief
jaeger29 May 2017 13:07
I noticed that afterward as well
DonSchilli
29 May 2017 22:20
Hello... since I work in this field, I can only offer the following advice....
The most important thing is always the detailed scope of work and the company contract.
Always have a professional review and evaluate them...
Many experts do this free of charge out of self-interest or curiosity....
Whether with or without land,
whether with or without financing,
whether with or without a show home,
whether with or without negative or positive press on Google... it doesn’t matter at all...
You never really know what is going on behind the scenes...
Insist on at least 2-3 visits to real customers of the builder...
That’s when you get a clear picture... real customers, real houses (not just website advertisements, etc.)
That makes the difference...
Good builders, especially medium-sized ones that don’t work like a production line, recommend this straight away... and rightly so....
I know homeowners who saved over 50,000 and received the same or better quality with smaller builders....
11ant30 May 2017 02:01
This is a kind of Murphy’s law in forums:
As soon as someone makes a statement like this
The thread is 5! years old, That person made their last post 3! years ago...
- suddenly a post from the category
DonSchilli schrieb:
Hello... since I work in this field, I can only advise the following....
shows up.
As if I had bet on it.
