ᐅ After the attic conversion, the KALLAX no longer fits into the niche – should it be shortened?
Created on: 23 Sep 2024 10:17
dilucas
I am currently facing the following problem: After our loft conversion, the niche where our KALLAX shelving unit used to fit is unfortunately no longer wide enough, so the furniture no longer fits there. The width of the niche has decreased by about 5 cm (2 inches) due to changes in the roof slope and interior walls. The shelving unit itself is made of relatively rigid panels, and I am wondering if it would be reasonable and safe to shorten the KALLAX in width to continue using it. Has anyone had experience with this kind of modification? Are there any risks regarding stability or appearance that I should consider? Or would you rather recommend getting a new, custom-sized piece of furniture? Any opinions and advice are welcome!
Domau0 schrieb:
The KALLAX shelf from IKEA is made of MDF with a melamine coating, which provides a stable structure, but mechanical modifications to the carcasses carry some risks.I want to go into more detail: MDF becomes more brittle when cut because its fiber structure is interrupted. When sawing, a suitable saw with fine teeth should be used to avoid chipping and flaking of the melamine surface. Then, the cut edges should be thoroughly sealed, for example with edge banding or a double-sided veneer strip, to prevent moisture damage.
For the back panel, it is advisable to cut it together with the shelf, as otherwise this can cause uneven load distribution in the structure. After cutting, all screws and nails should be reset, possibly with additional metal brackets, to restore the original stability.
I wonder whether the other option—buying a custom-made shelf or redesigning the niche—is actually less labor-intensive. How often will the shelf be heavily loaded? Will it hold documents, heavy equipment, or just light decorations?
That could strongly influence the decision.
