ᐅ Single-family house floor plan, 1 full story, utilities and natural lighting
Created on: 22 Jul 2024 08:21
klabauter8614
Hello, I would like to gather feedback on the floor plan in order to finalize the design. We don’t have sections or elevations yet, but all other drawings are attached (house shown schematically on the site plan). Thanks.
Plot size: 473m² (5,089 ft²)
Slope: no
Site coverage ratio: 0.4
Floor area ratio
Edge development
Number of parking spaces: maximum 2 without garage
Number of floors: 1 full floor
Roof type: gable roof
Architectural style
Orientation: Roof facing NNE - SSW
Maximum heights / limits: eave height 4.2m (13.8 ft), ridge height 9.5m (31.2 ft)
Further requirements: only renewable energy sources, infiltration trench for stormwater
Basement, floors: no basement (groundwater level at 1m (3.3 ft) depth), 1 full floor
Number of occupants, ages: 4, aged 40-40-7-2 years
Space needs on ground floor and upper floor: Guesst room on the ground floor, office upstairs
Office use: family use or home office? Home office
Number of guest stays per year: 2 nights per week by one parent (also for coming years), parents-in-law stay several weeks annually
Open or closed layout
Traditional or modern construction
Open kitchen, kitchen island: semi-open (sliding door), kitchen island
Number of fixed dining seats: 6 fixed, expandable
Fireplace: no
Music/speaker wall: no
Garage, carport: garage
Utility garden, greenhouse: herb garden
Additional wishes/special points/daily routine, including reasons for preferences or exclusions
Planner: synergy between architect and client, now 4th draft
What do you particularly like? Why? Guest room and WC + shower, similar existing layout already working (although a bed is drawn, it is actually a sofa bed), office on the north side, guest room size more than sufficient, wardrobe by the entrance, living room bright, washing machine + dryer upstairs.
What don’t you like? Why?
- Utility room is half unusable due to wardrobe protrusion (which is actually sensible) so it is too small. Attic storage needs to be moved from the garage into the thermal envelope inside the utility room, indoor unit could stay there. The mechanical ventilation system would also need to be installed in the utility room. Possible solution: enlarge kitchen to the rear and expand utility room accordingly. This would make the house larger though. No other solutions discussed yet.
- Stairs are too steep; architect now proposes a rise/run of 17.2cm/26cm (6.8"/10.2"), which may be borderline regarding comfortable step depth.
- Daylight in children’s rooms might be low due to west-facing windows and roughly 12.5% window-to-floor area ratio; simulation might be needed. Skylights wouldn’t significantly improve this; only a dormer and smaller gable windows would.
- As drawn, the kitchen island layout is not suitable for me; passage from utility room too narrow, should be moved to the opposite side, with sink and window to the left.
- Air conditioning would still be needed in the bedroom and children’s rooms, but with the current window and furniture arrangement this looks impractical.
- Shower upstairs located under sloped ceiling, not necessary but a minor point.
- Skylight in guest WC is not at head height, should be slightly higher, also a minor detail.
- Bathroom door upstairs should open outwards.
- Storage under the stairs is still missing.
- Partition wall in garage is unnecessary.
Cost estimate from architect/planner: unknown
Personal price limit for house including fixtures: 650,000
Preferred heating technology: air-source heat pump
If you must give up something, which features or extensions
- Can you give up: walk-in closet
- Cannot give up: office, guest room
Why is the design like it is now?
Own design developed based on space requirements plus architect’s counter proposal
What do you consider especially good or problematic?
Main issues to resolve are utility room + technical space and daylight.
Slope: no
Floor area ratio
Edge development
Architectural style
Fireplace: no
klabauter8614 schrieb:
Question: Is only the general contractor (GC) aware of the roof thickness? Isn’t that usually determined during the detailed planning phase?Yes, but your planner is employed by the GC, right? The final thickness of the roof of course also depends on your requirements and specifications.By the way, your planner has drawn 46cm (18 inches) walls. Which KfW standard does that correspond to, and is that really necessary? I mean, are there still significant amounts in terms of funding programs? I’ve been out of the loop for a while and wonder if that is really an advantage right now.
klabauter861420 Aug 2024 21:46Things forgotten in the agreements: The passage between the garage and the utility room/kitchen was changed into a “possibility for short routes from the entrance.” And a few other details, like the large window wall in the living room (my partner really liked it, although while it might look nice, it also means full sun exposure that will then require shading), were described more as a “bright living room,” as @ypg pointed out, rather than specifying “there must be a 4-meter (13 feet) wide floor-to-ceiling window wall” or looking for an option for a lean-to roof over the terrace. It seems these elements were simply carried over from the previous design without further consideration.
klabauter861420 Aug 2024 21:55K a t j a schrieb:
Yes, of course. Your planner is employed by the general contractor, right?
How strong the roof ends up being obviously depends on your requirements and specifications.
By the way: Your planner has designed 46cm (18 inches) walls. Which KfW standard is that for, and is it really necessary? I mean, are there still significant subsidies related to the funding program? I haven’t kept up for a while and wonder if it’s really an advantage right now. No, independent architect + structural engineering firm, no general contractor.
KfW40, double-shell 17.5cm (7 inches) masonry + 16cm (6 inches) mineral wool insulation, 1cm (0.4 inches) air space, and 11.5cm (4.5 inches) brick cladding. I believe the roof has external rafter insulation.
KfW40, double-layer 17.5cm (7 inches) masonry wall + 16cm (6.3 inches) mineral wool insulation, 1cm (0.4 inches) air gap, and 11.5cm (4.5 inches) facing bricks. I mean roof insulation above the rafters.The question was actually whether there is currently any meaningful financial support for this? Weren’t most of the funding programs largely discontinued at some point, or was the amount rather insignificant compared to the expenses? Or is it still worthwhile?klabauter8614 schrieb:
No independent architect + structural engineering firm, no general contractor.Oh really? Did you hire them directly yourselves? That’s a bit disappointing, isn’t it?klabauter8614 schrieb:
The following agreements were made:
- The upper floor layout should remain as in the original post, with 2 children's rooms on the right, an office to the north, bedroom and bathroom on the left. The office in the north is only optional due to heating and disruptive sunlight on the screen in the south. If there is a reasonable way to avoid this in the south (other than having the roller shutter down all day), the office can also be placed in the south as in #39. I still haven’t received an answer regarding which release version you wanted to keep for the ground floor, but I won’t ask a third time. For a glare-free monitor, a venetian blind is sufficient; there is no need to avoid sunlight exposure for the office.
- Two sketches should be made within a few days to reach agreement on the preliminary design. Only then should a complete design be created.
- The staircase should have a minimum of 16 steps with approximately 17/29 or a maximum of 18/27 (rise/run in centimeters (inches)), and all technical installations should be within the thermal envelope.
- Then, based on the sketches, combine and further develop them into a satisfactory preliminary design in 1-2 meetings, and only after that draw the full design.
For some inexplicable reason, these steps have not been carried out, which looks more like an internal communication issue (I had to wait several weeks again and only received 1 design). We still have one meeting this week, and we will then take the time to produce a proper preliminary design (thanks also to the brave help of @K a t j a and @ypg). You still don’t seem to understand what preliminary design and design mean (and neither does the planner). A preliminary design is not produced once per round or as a warm-up, but only once in one, two, or three variants during the entire house planning process. Exactly one of these is chosen to be further developed, while all others are immediately discarded forever in the planning office’s trash bin. All change discussions take place on this single preliminary design, in one meeting — not back and forth, and not repeatedly. This can take weeks but should always be through dialogue (discussion), never ping-pong (back-and-forth), and certainly not multiple times. This must be fully completed before the preliminary design (singular!) is developed into a final design. From then on, there are no further designs, only revisions. You can find the design seminar on "Bauen jetzt," for example in "A House Construction Roadmap, Also for You: The HOAI Phase Model!". Of course, you can do it differently if you have too much money, time, or patience (or want to let a "planner" experiment and learn). *
(most clients only commission a planner up to the building permit / planning permission and then request offers from multiple general contractors, which of course leads to a wide range of offers). You should actually work with the architect through service phases 5 to 7 after approval — but to make sense of that, you should of course not commit to a general contractor beforehand (neither in general nor to a specific one).
Question: Does only the general contractor know the roof thickness? Isn’t this determined during detailed design? Katja probably meant that only the general contractor knows the "secret" regarding the "wall construction" (whose thickness is relevant here) planned for the roof.
K a t j a schrieb:
By the way: Your planner has specified 46cm (18 inches) walls. Under which KfW standard are we for that, and is that really necessary? In addition, I question the outer masonry shell for the garage structure. I would have only planned that for the house and cladded the garage with facing bricks.
KfW40 standard, double-wall with 17.5cm (7 inches) masonry + 16cm (6 inches) mineral wool insulation, 1cm (0.4 inch) air gap, and 11.5cm (4.5 inches) brick veneer. I believe the roof has exterior (above-rafter) insulation. Independent architect, really? I cannot believe that. That is drafting-level planning quality. A shame. Hopefully at least well below the benchmark! (or even level 4 because of the facing brick?)
*) In this specific case, however, I would deviate from the described approach as follows:
1. Discard previous designs and no longer use them as a basis for any improvements
2. Declare a successful design (for example, Katja’s from release version post #86) as the new and only valid preliminary design to be further developed.
The recycling bin as a document management tool is greatly underestimated!
