ᐅ Garage built taller than specified in the building permit/planning permission
Created on: 23 May 2022 08:29
Nixwill2
In our building application, we specified the garage with a height of 2.68 meters (8 feet 9 inches) for some reason. The garage is properly located at the edge of the property on the area designated as GA in the development plan.
Would it be possible to build the garage 3 meters (9 feet 10 inches) high instead, contrary to the application, or do we have to stick to the approved plans? The construction is taking place in Baden-Württemberg.
The question arises because we are quite certain that we will not actually build a garage there. Instead, a carport is planned, which will be greened. Therefore, we would like to make use of the maximum permitted height.
WilderSueden
24 May 2022 13:59
Tolentino schrieb:
Who comes up with 9 and 15?
3x3 and 5x3? 😀
I also find it puzzling whether this really needs to be regulated again when the wall area facing the neighbor is already limited, and thus implicitly the lengths as well.
Nixwill224 May 2022 14:02
driver55 schrieb:
The garage that is or will become a carport…
Exactly, good observation. We are having a garage designed but will most likely only build a carport.
We assume no one will mind (or do you think/know otherwise?).
netuser
24 May 2022 14:49
Nixwill2 schrieb:
We assume that no one will mind (or do you think/know otherwise?).
In this case, I don’t know of anything different, but in some building areas, carports are prohibited. Just mentioning it in passing 🙂
Nixwill224 May 2022 15:01
Fortunately, that is not the case for us; the development plan always refers to both. Additionally, we have planned another carport directly attached to the house, which will be built together with the house and will also enhance our entrance area 🙂.
Tolentino24 May 2022 15:21
WilderSueden schrieb:
3x3 and 5x3? 😀
I also find it puzzling whether this really needs to be regulated again, since the wall area towards the neighbor is already limited, which implicitly limits the lengths as well.
Ok, both are multiples of the maximum height after all, that’s true. I can live with that.
Pinkiponk
24 May 2022 18:53
For us, it will be the exact opposite. Our approved plans include a parking space with a carport behind it, but we have now decided to build a garage instead. Even a proper one, ;-) with bricks and all. I am currently researching what is allowed and what isn’t.
