ᐅ Garage built taller than specified in the building permit/planning permission
Created on: 23 May 2022 08:29
Nixwill2Hello everyone,
In our building application, we specified the garage with a height of 2.68 meters (8 feet 9 inches) for some reason. The garage is properly located at the edge of the property on the area designated as GA in the development plan.
Would it be possible to build the garage 3 meters (9 feet 10 inches) high instead, contrary to the application, or do we have to stick to the approved plans? The construction is taking place in Baden-Württemberg.
The question arises because we are quite certain that we will not actually build a garage there. Instead, a carport is planned, which will be greened. Therefore, we would like to make use of the maximum permitted height.
Well, we can’t easily answer the question of what is allowed in your area. Here in Bavaria, building on the boundary line is not permitted to exceed 3 meters (10 feet) in height, measured from the natural ground level; otherwise, setback distances must be observed. I don’t know if the same rules apply where you are, or if the natural ground level there was higher than your new garage floor / carport floor.
