ᐅ Is the price for the townhouse kitchen too high or reasonable?
Created on: 28 Jul 2021 22:03
ToFi1988
ToFi1988
28 Jul 2021 22:03
We will be moving into our newly built terraced house this fall/winter. The kitchen is open-plan but somewhat small—we are trying to make the most of the space. We have consulted with 2-3 kitchen planners. With one planner, we went into detail and after several appointments found a solution that we really like. Now, I would appreciate an external opinion on whether the kitchen is overpriced or reasonably priced. It would also be helpful to get feedback on the appliances. I am grateful for any assistance.
The construction site is near Neumarkt in the Oberpfalz region.
The kitchen is L-shaped including a kitchen island. The island is used solely as a work surface, with the appliances installed along the wall.
The kitchen planner is a new company, which originated from PlanA.
Here are the details as per the quotation:
M1:
Supplier is Inpura Classic, Comet, front in spatula concrete finish, Nova pro Module C.
M2:
Templer natural stone, satin finish 30-100 mm (1.2-4 inches), thickness 20 mm (0.8 inches), type Nero India.
Kitchen block L:
6x base cabinets
Side panels made of plastic
6x anti-slip mats
Duo built-in power outlet unit
Sink base cabinet
KeraDomo undermount sink
Blanco Linus-S HD with pull-out spray nozzle
Waste bin
2x cooktop base cabinets 80 cm (31.5 inches)
Cutlery insert
2x wall cabinets
2x Livello LED lighting
Countertop:
Natural stone satin finish 30-100 (1.2-4 inches), thickness 20 mm (0.8 inches) Nero India
Part 1:
Width 2450 mm (96.5 inches)
Depth 585 mm (23 inches)
Height 40 mm (1.6 inches)
Includes processing
Part 2:
Width 2280 mm (90 inches)
Depth 640 mm (25 inches)
Includes processing
Part 3:
Width 1850 mm (73 inches)
Depth 935 mm (37 inches)
Includes wall connection strips
Appliances:
Siemens dishwasher SN63EX14BE
Siemens steam oven HS836GVB6
Siemens glass-ceramic cooktop EX807LVV5E
Siemens wall-mounted hood LC87KEM60
All including installation.
I have received a gross offer of 17,000 euros.
Thank you for your opinions, assessments, suggestions for improvement, and help.
Many thanks!
2D-Grundrissplan eines Hauses mit Küche, Wohnzimmer und Schlafzimmer
Moderne Küche mit grauen Schränken, schwarzer Arbeitsplatte, Insel, Ofen, Abzugshaube, Fenster.
driver55
28 Jul 2021 22:23
No one here can reasonably assess that.
Take the order confirmation and request a quote for the same kitchen from two other studios, then you'll be wiser.
Some individual items are also available for separate purchase.
What price is being asked for it?
ToFi1988 schrieb:
Blanco Linus-S HD with pull-out spray hose
Or is there only an overall price and no breakdown of single items?
That’s what it looks like with that round price. 🙄
The “spray hose” is available for about 170€ (approximately 180 USD).
Nida35a28 Jul 2021 22:28
I don’t see a refrigerator; otherwise, the price seems accurate.
Bookstar
28 Jul 2021 22:30
The price is good and absolutely reasonable. It’s a viable option.
28 Jul 2021 22:32
It’s the unknown details that make a kitchen expensive.
ToFi1988 schrieb:
Front in spatula concrete
Plastic with a spatula finish? Or real concrete?
ToFi1988 schrieb:
Templer natural stone, satin finish 30-100 mm (1-4 inches), thickness 20 mm (0.8 inches), type Nero India
The same?
ToFi1988 schrieb:
Waste collector
These also come in various sizes… small container on the door or waste sorting system inside the drawer.
ToFi1988 schrieb:
Cutlery insert
30 cm (12 inches), 90 cm (35 inches), plastic or wood?
ToFi1988 schrieb:
6x base cabinet
Doors? Drawers? Full extension?
If everything is standard, as I assume (plastic fronts, common 60 cm (24 inches) drawer inserts), then the price seems normal. What’s important is that you have matched your personal value and that it is worth €17,000 to you. Kitchens are difficult to compare.
Myrna_Loy
28 Jul 2021 23:00
The price seems reasonable, but why is the sink placed right next to the tall cabinet and directly adjacent to the cooktop? This is a kitchenette layout and ergonomically unsuitable for efficient workflow.
