Created on: 31 Jan 2020 13:29
Shiny86
Slope yes
Site coverage ratio?
Floor area ratio?
Boundary development?
Number of parking spaces 2
Number of floors 2
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
What don’t you like? Why?
Good: large living area
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Okay, maybe just a terminology confusion:
Base = the area beneath the main cabinet body
This is usually covered by a baseplinth, so that the cabinet feet are not visible. Of course, the base plinth is then cut out to create a kind of cavity or garage for the vacuum cleaner. The base plinth remains intact on the right and left sides.
In our case, the robot parks under the kitchen island, so the power outlet is located in the floor there. To access it, there is the mentioned hatch in the cabinet, but if necessary, you can also reach the outlet by removing the baseboard and accessing it while lying on the floor.
Shiny86 schrieb:
Yes, then you just open the utility room door and drive out. I also have to place a few things up high, like a floor lamp. How would you solve that? I find under the sofa somewhat inelegant. The utility room isn’t exactly quiet. The heating system noise plays a part in that, at least with a gas heater. I don’t know how it is for you.
Maybe a robot vacuum isn’t suitable for every household, I’d say.
How do you handle spider webs that form higher up in the corners rather than just near the floor? I regularly vacuum corners and walls (including ceiling corners), so I avoid relying on a cute robot vacuum. The constant rearranging or placing things up high would annoy me too. A robot vacuum is an option for cleaning when you’re not at home, right?
