ᐅ Floor Plan Optimization for Urban Villa + Considerations for Land Elevation
Created on: 31 Jan 2020 13:29
Shiny86
Plot size 492 sqm (5293 sq ft)
Slope yes
Site coverage ratio?
Floor area ratio?
Building envelope, building line, and boundary?
Boundary development?
Number of parking spaces 2
Number of floors 2
Roof type Pyramid roof, 25 degrees
Architectural style Modern urban villa
Orientation Main entrance facing north
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Modern urban villa with pyramid roof, 25 degrees
Basement, floors 2 full floors without basement
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
Large living area, master bathroom
What don’t you like? Why?
Utility room quite small and master bedroom small, children’s room somewhat too large
The architect implemented the corresponding wishes
What do you think is especially good or bad about it?
Good: large living area
I am uncertain about the half-height window sizes and the swing direction of the doors
  • Where could it still be optimized? Would you recommend different window dimensions or sill heights?
  • What do you think is poor or what would you do differently?
  • A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
  • Is the hallway on the ground floor too narrow?
  • Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
  • Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
  • Is the kitchen size sufficient for a nice kitchen with an island?
What do you think about the floor plans?
Floor plan of a single-family house: living/dining area, kitchen, hallway, storage room, cloakroom, WC.
Floor plan of a family home: CHILD 1, CHILD 2, PARENTS, WALK-IN CLOSET, BATHROOM, SHOWER/BATHROOM, HALLWAY.
Architectural drawing: two-story residential house with garage; southwest and northeast views.
Two facade views of a house: northwest and southeast with roof, windows, terrace, and garage.
opalau9 Oct 2020 08:52
You should separate the concepts of router and access point in your mind, which makes it easier to understand. Ideally, you use the router—the device provided by your internet service provider—only for the initial connection, not for broadcasting the Wi-Fi. For good Wi-Fi coverage, it is recommended to place an access point on each floor. An access point is a device dedicated solely to providing Wi-Fi. You connect these access points to your router. As mentioned earlier, such access points can be conveniently installed on the ceiling. A network cable outlet in the ceiling is sufficient because the access points can also be powered through it.
derschwax
9 Oct 2020 09:12
So, are there smoke detectors installed inside the rooms and, for example, in the hallway, both a smoke detector AND an access point mounted on the ceiling?
Nida35a9 Oct 2020 09:15
and a lamp,
are there already lamps with an access point and smoke detector integrated?
Tolentino9 Oct 2020 09:18
So with RM definitely in the lamp (not ideal) I have never seen a lamp or smoke detector with an integrated access point, let alone both together...
edit: Apparently there are light bulbs with an integrated repeater...
Pinky03019 Oct 2020 10:14
In our case, it will not hang from the ceiling but on the wall just below the ceiling.
hanse987
9 Oct 2020 10:27
Pinky0301 schrieb:
In our case, it will not hang from the ceiling but be mounted on the wall just below the ceiling.
That can also work. However, you should check the datasheet of the access point to see which mounting position the antennas are optimized for.
