ᐅ Kitchen Photos Thread – Show Us Your Kitchens!
Created on: 16 Aug 2018 10:03
DieScholz´ens
Bought a house, estimated the renovation budget plus 10-15% for inevitable extras, and we set aside 5000 EUR for the kitchen!!!!
That’s how it started... at first, I was in a bit of shock, but we still had time. First step: remove all the walls for a new layout—I need space...
Let’s start with the (according to the agent) move-in ready property. The small kitchen, just under 8 square meters (about 86 square feet), had its 1970s pass-through removed. The wall including the kitchen door is gone! The wall next to the cellar stairs is gone too! Actually, the entire slanted wall, nearly 7 meters (23 feet) high, removed completely...
The window had to go as well since we needed a different working height than the standard 90 cm (35 inches). New screed installed, we switched to underfloor heating, all electrical wiring and water pipes are new.
After almost six months, the realization slowly sank in: the kitchen budget will not exceed 5000 EUR, so we had to look for a used kitchen... something special, but very cheap.
The search criteria: within a 100 km (62 miles) radius, up to 1000 EUR, because I still want new appliances.
Open living area with modern white kitchen, bright flooring and lots of light
Kitchen area with red tiled backsplash, white base cabinets and window
Bright, empty living room with white walls, laminate flooring and built-in shelf.
Bathroom under construction with floor tiles, red wall tile and sanitary connections
Kitchen shell with tiled floor, building materials and open ceiling during renovation
Construction site inside house with bare walls, cables and construction waste.
Child in winter jacket looking at unfinished interior with exposed walls and construction work.
Two workers renovating interior; exposed walls, tools and cable reels visible.
Interior finishing and remodeling: construction work in renovated space with open installations.
Peter Silie
29 Aug 2020 20:32
pagoni2020 schrieb:
I already found it quite homely in November 2019
That is already the nicer version. Before that, there were tiles stacked in the pantry on the wall, old water supply and drainage pipes, and we generally had to do a lot of plastering.
aero2016
29 Aug 2020 22:09
For the wall cabinets/cupboards on the right, I would consider a different solution. It's very patchwork as it is.
Peter Silie
30 Aug 2020 10:22
aero2016 schrieb:
For the wall cabinets on the right, I would consider something different. It looks very pieced together.
The cabinet is aligned with the left wall cabinet, there will be a microwave above the oven, and the rest is countertop space. What exactly looks pieced together there?
aero2016
30 Aug 2020 14:07
Peter Silie schrieb:
The cabinet is aligned with the left wall cabinet, a microwave will be placed above the oven, and the rest is countertop space. What exactly is pieced together here?
Individual wall cabinets always look quite scattered. That’s the first point to consider.
The cabinet to the left of the range hood also doesn’t match the tall cabinet on the right at all.
There is no alignment or continuous line. And on the tall cabinet, it looks quite odd that one handle is centered while the other is placed to the side.
There’s nothing visually appealing about that.
aero2016
30 Aug 2020 14:09
And what do you want to do with 6 outlets in that small corner?
Peter Silie
30 Aug 2020 15:01
aero2016 schrieb:
And what do you want to do with 6 sockets in that small corner?
We will plug a Thermomix into each one.
