Created on: 31 Jan 2020 13:29
Shiny86
Slope yes
Site coverage ratio?
Floor area ratio?
Boundary development?
Number of parking spaces 2
Number of floors 2
Maximum heights/limits
Additional requirements?
Clients’ Requirements
Number of occupants 4
Open kitchen, kitchen island
Number of parking spaces 8-10
Garage
Who designed it?
-Architect
What don’t you like? Why?
Good: large living area
Slope yes
Floor area ratio?
Number of floors 2
Garage
Who designed it?
-Architect
- Where could it still be optimized? Would you recommend different window dimensions or sill heights?
- What do you think is poor or what would you do differently?
- A partition wall will be added in the walk-in closet. That would theoretically allow watching TV from the bed. I am considering a lightweight wall. I plan to place a 211cm (83 inches) Pax combination wardrobe in the closet. The closet is planned with a raw width of 218cm (86 inches). Do you think 218cm is enough for the Pax once the walls are plastered, or how wide should the rough dimensions preferably be?
- Is the hallway on the ground floor too narrow?
- Would you raise the ground level? The house would be 40cm (16 inches) below street level. If I build a terrace into the garden, it would be about 1m (3 ft) difference. You could raise only the house level, resulting in approximately 1.6m (5 ft) difference between terrace and garden. I don’t know anyone living below street level. Raising the garden would probably not be allowed without permits, and affected neighbors likely wouldn’t agree. On the sides of the house adjacent to neighbors, raising is permitted only up to certain limits. I am overwhelmed with the decision.
- Do you have any ideas for arranging the sofa differently and placing the TV sensibly? My husband doesn’t want the sofa back facing a window. I still need to get used to placing the sofa in the middle of the room.
- Is the kitchen size sufficient for a nice kitchen with an island?
Shiny86 schrieb:
Do you find a guest toilet next to a living room wall bothersome? Can you always hear the flushing?You can hardly hear the toilet next door, as only the cistern is adjacent. A toilet one floor above would be audible—in that case, it’s the waste pipe whose noise you would "enjoy." Shiny86 schrieb:
Was the wall intentionally built so thick?Load-bearing walls with a thickness of 24 cm (9.5 inches) are not unusual; in the past, the now more common 17.5 cm (7 inches) thickness was used less frequently. However, you don’t really hear the wall thickness itself, but rather the wastewater accelerating down the soil pipe.https://www.instagram.com/11antgmxde/
You can hardly hear the bathroom next door since only the flush tank is adjacent.Is there a way to make it completely soundproof? Are guest bathrooms often located next to living rooms?
Shiny86 schrieb:
Is there a way to make sure it’s not audible at all? Are guest toilets often located next to living rooms?There are soundproofing bricks with higher bulk density, which we used around the utility room.
Sabine
Alessandro20 Apr 2020 11:15Install a light switch/motion sensor in the bathroom that is connected to a flush-mounted radio, so guests can also turn up the volume.
The bathroom window will be shaded most of the time.
