ᐅ Experiences with Poroton S9 or T9 Blocks
Created on: 11 Jul 2013 10:09
jayden1977
jayden1977
11 Jul 2013 10:09
Hello experts,
I’m new here and really excited to have found this site. We plan to build next year and are still in the planning phase. The following points are very important to me for the build.
- Solid construction with Poroton (36.5 cm (14.4 inches) exterior wall)
- Without ETICS (external thermal insulation composite system)
- KfW 70 standard
- Air-to-water heat pump
- Underfloor heating
- Triple-glazed windows
I want to build with Poroton, but I already have some doubts. I’ve read a lot about filled Poroton bricks like T7, T8, T9, and Unipor Coriso WS08. My question is whether I could also use an unfilled Poroton brick, such as Unipor WS09 or T9 plan bricks. I contacted Wienerberger to ask which bricks would be suitable. They said that the filled bricks are good, but if unfilled and without external insulation, then the T9 plan bricks (36.5 cm (14.4 inches)) would be recommended.
Is this suitable for a KfW 70 house, and does anyone here have experience with this? Alternatively, I would consider using the filled bricks, but I’m not sure about the practical experience with those, especially combined with perlite or mineral wool.
Thank you very much for your answers.
Regards,
jayden1977
jayden1977
12 Jul 2013 12:09
Hello experts,
No suggestions or answers. I would really appreciate having some opinions. The views from the developer vary greatly.
Regards
Jayden
Vit8414 Jul 2013 01:42
Why did you decide against aerated concrete? Are there important reasons for your choice of Poroton?
backbone23
14 Jul 2013 23:02
What do you think are the disadvantages of solid bricks?
jayden1977
15 Jul 2013 08:53
I would not recommend aerated concrete because sound insulation is very important to me. I have a large family with many young nephews (6 boys), and I have two boys myself. Additionally, I plan to build near railway tracks (train station). My brother-in-law has built with Ytong, and apart from its excellent thermal conductivity and ease of installation, I wasn’t very impressed.
Thermally insulated clay blocks are also very good, but which ones? There are the T Series from Wienerberger, but I thought the webs are too far apart. If I want to screw in small screws, I would hit the insulation material—whether mineral wool or perlite—or I could use the Coriso blocks from Unipor, which I like a lot but they are quite expensive.
What has been your experience with thermally insulated clay blocks?
Jayden
MeisterPhillip
15 Jul 2013 09:34
I’m not a fan of highly insulated, filled bricks like T7, T8, or T9. These try to turn a "brick" with load-bearing functions into something it wasn’t meant for. These systems only work in theory.
The thin-walled brick material is brittle and prone to cracking. Many bricks break already during rough unloading of pallets on site. At highly stressed points, such as supports for lintels, damage often occurs during masonry work. This later becomes visible in the exterior plaster.
Working with the bricks in thin-bed mortar is also not without challenges. You’re supposed to have a continuous mortar layer without contamination from the perlite. The reality looks different.
The actual insulation, which is the perlite filling, constantly has thermal bridges because gaps are simply filled carelessly with mortar or plaster, or the filling falls out during cutting and the brick is still used. Every electrical outlet on the outer wall also reduces the U-value compared to an external thermal insulation composite system (ETICS / external wall insulation).
There are many other aspects, but that would go beyond the scope here. For monolithic construction, I find aerated concrete (e.g., Ytong) much more practical. For high energy efficiency demands without annoying thermal bridges, there is no way around full external insulation.
Regards,
Phillip
