Dear forum members,
We bought a plot of land last autumn and are currently deep into the floor plan design. We would like to share our current draft with you and welcome any comments and opinions.
[F]irst some preliminary information about the plot and its buildability:[/F]
- 1000 m² (10,764 sq ft) rear plot, southwest facing (so southwest is on the left side of the site plan)
- Building boundary up to approx. 16 m (52 ft) behind the property line (up to the dashed line on the site plan)
- No zoning plan (construction according to § 34 of the Building Code)
- Groundwater at surface level and peaty soil (exact geotechnical report pending), so piled foundation required and no basement
- Affordable! (Our maximum budget for the house including foundation slab is €230,000)
- Country house style
- Bright, large windows facing south/garden
- Open living/dining/kitchen area
- Family of four, 1 bedroom and 2 children’s rooms
- Not oversized, max 150 m² (1,615 sq ft), preferably less
- Solid construction using Ytong blocks (for us the most cost-effective option, although we would have liked to build with wood as well).
- Developed ourselves after studying various floor plans (including from the book "Affordable Building with a Small Budget" by Achim Linhardt) with support from architect friends and our planner (an independent civil engineer).
- Dimensions 12.50 x 7.50 m (41 x 25 ft) (the measurements shown on the site plan are from an earlier draft).
- What we like: open living area, all main rooms have large windows facing the garden, efficient size, although the children’s and bedroom could be smaller, sewing/work nook behind the stairs upstairs, plenty of wall space for large wardrobes in the upstairs bedroom and hallway on the ground floor, light shaft in the stairwell, staircase (we originally wanted a straight run staircase but it would have taken too much space; the one with three quarter turns is also fine with us).
- What we don’t like 100% yet: the height of the house from the outside. It is currently planned as a two-story house with an eaves height of 6.2 m (20 ft), with the ground floor 2.84 m (9 ft 4 in) high and the upper floor 2.60 m (8 ft 6 in) high. The gable roof will be an uninsulated, unfinished cold roof, mainly because of the economical prefabricated truss construction method. This is a bit disappointing because I really like sloped ceilings and did not want the character of a townhouse. Lowering the roof with a knee wall of about 1.90 m (6 ft 3 in) and an insulated roof with open sloped ceilings would probably be more expensive due to the rafter/beam construction. We would also lose the garden view through the floor-to-ceiling bedroom windows.
- Simple: What do you think about the floor plan?
- Can you still imagine the relatively tall two-story house having a country house character? Maybe it depends on the facade design and choice of materials? Do you think it looks too “blocky,” especially from the front entrance side? Or would a lower eaves height with an attic conversion including a knee wall be preferable?
- We are still unsure how to arrange the windows on the garden side. The drawing with the elevations shows two possible versions. We actually prefer it when the upper floor window is centered over the lower window front. However, this does not align the interior line of sight from the entrance door to the garden/patio door (see ground floor plan). This represents version two; for version one, the window front would have to be shifted about one window width to the right, so that the patio door is behind the dining table. With the window front shifted left, the interior looks better to us, but from the outside it looks strange if it is offset from the upper floor window, right? What do you think?
Due to the risk of mold, it should be 5-10cm (2-4 inches)! However, this mainly applies to older buildings with cold walls rather than new constructions.
Pinky0301 schrieb:
This mostly applies to older buildings with cold walls rather than new constructions.... and exterior walls.Altai schrieb:
... and on exterior walls.... from older buildings or houses that are not sufficiently insulated. I strongly doubt that walls behind furniture in a KfW55-standard house would start to develop mold. Sorry for the off-topic...Pinky0301 schrieb:
... from old buildings or houses that are not sufficiently insulated. I highly doubt that the wall behind a piece of furniture in a KfW55 house would start to mold. Sorry for going off-topic...No, also new buildings.
Viebrockhaus, especially with their 3-month houses, are particularly prone to mold forming behind bathroom mirrors.
It is the construction moisture trapped in the walls that needs to be released. That is why regular ventilation is necessary... for up to 2 years to remove the moisture from construction. This is a fundamental principle in house construction!
In the past, homes were lived in dry conditions. That no longer exists today.
Pinky0301 schrieb:
... from older buildings or houses with insufficient insulation. I seriously doubt that the wall behind furniture in a KfW55 house would start to develop mold. Sorry for the off-topic...Otherwise, it wouldn't really be a KfW55 house.Here are my observations.
The layout of the ground floor fits the cardinal directions very well and does not need to be changed. Kitchen in the southeast, living room in the south and southwest extending to the northwest. It works.
The ground floor can remain open if desired, although I would reconsider the staircase. A staircase partially separated from the living room might be more practical, even if it lacks a bit of style.
The upper floor fits quite well. I would improve the bedroom by placing the small ironing room to the northeast and the bedroom itself to the southeast.
I would add a wall or similar to the gallery to create a storage room.
Now we have to wait and see how the prices develop.
Potential savings could be achieved by using Hansapor instead of Ytong. Instead of floor-to-ceiling windows, use standard-height windows. All windows in a common DIY store size, rough opening 102cm (40 inches).
