ᐅ Looking for Exterior Up/Down Lights – Purchase Recommendations Requested
Created on: 8 Dec 2019 20:12
I
Ippebson
Good evening everyone,
it’s about time for us to start thinking about the exterior lights.
That’s why I’m turning to the forum for recommendations.
We are considering LED up/downlights in window frame color (RAL 7016), with a cubic design. We need a total of six, one of which should have an integrated motion sensor but otherwise match the same design.
Until now, I believed that lamps with replaceable bulbs are better because you can simply replace the bulb when it stops working. However, most exterior lights seem to have the LEDs built in permanently.
What are your thoughts on this? Do you have any experience or buying recommendations to share?
Ippebson
Ippebson
The parameters suit us well; 4000 K is not that bright, our recessed spotlights in the entryway area also have 4000 K. 20 W is actually quite substantial, but the lights are only meant to be on when we are outside on one of the terraces. Considering the expected operating hours, I don’t mind. I also have to factor in the price. I will report back on how they perform.
Good luck
Good luck
hampshire10 Dec 2019 21:33Ippebson schrieb:
4000 K is not that bright,4000K can be either bright or dim because it refers to the color temperature, not the amount or intensity of light. Ippebson schrieb:
20 W is really not little20W can be low or high, as it indicates the power consumed, not the light output.Of course, these could be exactly the right lamps for you!
A quick tip for those searching to understand the relevant values
- Color temperature – unit Kelvin – Higher values >4000 similar to midday sunlight (towards blue), lower values <3000 similar to evening sunlight (towards orange)
- Color rendering accuracy – unit CRI – CRI>90 is considered relatively color-accurate.
- Light output – unit lumen – amount of emitted light. This is not the brightness.
- Light intensity – unit candela or lux – intensity of the light
- Beam angle – if relevant, in degrees – determines the intensity of light relative to the total light output
By the way, LED efficiency (light output per watt) inherently decreases with lower color temperature and higher CRI. This, however, does not significantly affect household electricity consumption.
