ᐅ Connecting a Washing Machine Drain to an Unusual Pipe
Created on: 3 Nov 2019 19:25
MissHoneyBee
MissHoneyBee3 Nov 2019 19:25
Here is my situation (see photo): the pipe I want to connect my washing machine to has an inner diameter of just under 60mm (about 2.4 inches) and goes in about 2cm (0.8 inches) until a lip. I have found various HT pipes, but they all correspond to DN58, which is 58mm (2.3 inches). Would one of these fit securely, or is the 2cm (0.8 inches) lip too short? Furthermore, there is a slight draft coming from the pipe that has a very unpleasant smell, so I definitely want to use a surface-mounted trap, but this is only available in DN40.
Is there anyone here who can advise me on which pipes and adapters would fit to go from this DN58 pipe down to DN40? It is important to me that no odors can get into the hose.
Thanks and best regards,
Mary
Offene runde schwarze Rohröffnung in grauer Fliesenwand mit rauem Betonrand.
Offener runder schwarzer Rohrstutzen in einer Fliesenwand, innen staubig.
hampshire
3 Nov 2019 19:35
It looks to me like an already sealing rubber gasket. DN58 should fit tightly, 2cm (1 inch) depth is enough. The siphon acts as a trap to prevent odors, in case you're worried your machine might start to smell. But this is hardly necessary. As a temporary seal, I would use a freezer bag stuck on or over it.
F
fragg
4 Nov 2019 09:04
You need a DN 50 pipe, which is the inner diameter. The outer diameter is about 60mm (2.4 inches). From there, you go down to DN 40, install your trap (or insert a siphon), and then you can connect the washing machine.
Knöpfchen4 Nov 2019 19:55
Most likely, a soundproof pipe system is installed here. Possibly Geberit. Either contact the landlord or ask a local plumber about the appropriate connection parts.
MissHoneyBee4 Nov 2019 22:02
fragg schrieb:
You need DN50, which refers to the internal diameter. The external diameter is about 60mm (2.4 inches). From there, you step down to DN40, install your trap (or a siphon), and then you can connect the washing machine.
I actually measured the internal diameter myself, and it was around 59mm (2.3 inches), with a wall thickness of about 4mm (0.16 inches). Now I’m really wondering if that can still be considered DN50.
MissHoneyBee4 Nov 2019 22:05
Knöpfchen schrieb:
It is probably a soundproof pipe system installed here.
Possibly Geberit.
Either contact the landlord or ask a local plumber about suitable connection parts.
I don't think it is something that high-quality; the pipe should correspond to the age of the house (built in 1972).
