Created on: 27 May 2019 10:48
goalkeeper
goalkeeper20 Sep 2019 10:31This could turn into something.
The geotechnical engineer still hasn’t provided a reliable foundation statement based on yesterday’s recommendation. The structural engineer has to ask for clarification again because an important statement was simply not made. It seems to be about the allowable soil pressure for the strip footings.
But the engineer will definitely issue an invoice for this, which I will certainly pay.
goalkeeper20 Sep 2019 10:37Zaba12 schrieb:
Strip foundation? Why?I can only infer this from the email exchange without knowing the full reasoning of all parties involved.
However, the solution with the L-shaped concrete elements and the embankment including a load-bearing slab was rejected by the structural engineer. The L-shaped elements would not withstand the pressure.
Therefore, they are now considering strip foundations—either in the cohesive or non-cohesive soil depending on the situation. For this, the structural engineer now requires the corresponding preliminary work from the surveyor.
This came from the structural engineer to the surveyor:
- Foundation of all footings (except the party wall) in the cohesive topsoil at
- approximately 101 m above sea level (331 ft). The topsoil will be removed and the footings will be founded on the cohesive soil. Does a required embedment depth need to be considered here?
- (The party wall foundation would be founded frost-free approximately 95 cm (37 inches) deeper)
- Foundation of all footings (except the party wall) in the non-cohesive gravel at
- approximately 100 m above sea level (328 ft). The topsoil will be removed... Can the foundation trenches then be backfilled with lean concrete up to approximately 101 m above sea level (331 ft)? After that, the footings would be built up to the underside of the slab level.
- The party wall foundation in this case (without lean concrete) would also be founded at about 100 m above sea level (328 ft) and would be continuously reinforced for frost protection.
goalkeeper20 Sep 2019 10:42Zaba12 schrieb:
Well, good nerves going forward. If the October 1st deadline holds, you still have a chance to have your house weather-tight by Christmas. For me, it started in mid-October last year (and the basement as well). The roof was erected on December 20th or 21st.Thanks – that's the plan as well.
