Created on: 27 May 2019 10:48
goalkeeper
Z
Zaba12
19 Sep 2019 12:05
goalkeeper schrieb:
He roughly explained it to me before: the floor slab will be made as a precast concrete element and will rest on the foundations.
Therefore, no expensive compactible material needs to be filled in between; the excavated soil can be used instead. The backfill no longer supports the floor slab but the foundations.
Once I know the exact implementation, I will gladly explain it here.
Sounds like a half-height precast concrete basement without access or windows, and the excavation is also removed or disposed of!
To me, that doesn't sound like 15,000 euros, but I’m happy to be proven wrong.
19 Sep 2019 12:14
Zaba12 schrieb:
Foundation at the neighbor’s basement depth? What will happen to the space between the foundation and the top of the finished floor?
A wall foundation about 250 millimeters (10 inches) deep, extending along the entire length of the house?
goalkeeper
19 Sep 2019 12:15
Zaba12 schrieb:
Sounds like a half-height precast concrete basement without access or windows, and it will also be excavated or removed!
To me, that doesn’t sound like 15,000 euros, but I’m happy to be proven wrong.
I’m pretty relaxed about it. So far, everything our general contractor has proposed has been solid and reliable. Since he has already discussed the matter thoroughly with the structural engineer, he’s probably right, and for 15,000 euros, this will likely be the most reasonable solution for us.
goalkeeper
19 Sep 2019 12:17
A wall foundation about 250mm (10 inches) deep, running the entire length of the house?
Let's not speculate any further. As soon as there is a final solution, I will gladly share it here.
Matthew03
19 Sep 2019 13:08
In a parallel universe, @goalkeeper would build on @AnniSke’s plot without a basement, while she would build one here with a basement... and everyone would be happy.
11ant19 Sep 2019 13:22
Zaba12 schrieb:
I can already hear the basement calling.
I can smell you calling it.
goalkeeper schrieb:
He had roughly explained it to me before: the concrete slab will be made as a precast concrete element and will then rest on the foundations.
Therefore, no expensive compactible material needs to be backfilled underneath; the excavation material can be used instead. The backfill no longer supports the slab, but the foundations do.
I don’t see any fundamental difference in structural design between cast-in-place and precast concrete initially (?).
Zaba12 schrieb:
Sounds like a half-height precast concrete basement.
Sounds like terracing – with no basement on one side and basement walls on the other side, without any rooms in between :-(
