ᐅ Why don’t the shelves fit properly in my BILLY bookcase?
Created on: 13 Dec 2021 17:36
Sin_je
Sin_je
13 Dec 2021 17:36
Hello everyone, I recently bought a Billy bookshelf from IKEA and wanted to install the shelves, but somehow they don’t fit properly into the designated brackets. The shelves either sit too loosely or are stuck in some places, so they can’t be placed exactly as intended. I have checked the measurements several times, and the holes all look evenly spaced, but the problem remains. Does anyone have any idea what might be causing this? Could it be the material, the manufacturing, or perhaps a step in the assembly process that I missed? I would really appreciate any advice.
FELOTAU
13 Dec 2021 17:54
Sin_je schrieb:
The shelves are either too loose or they jam in some places
That sounds really frustrating, especially when you think you’re doing everything right. I’ve had my own struggles with IKEA furniture because sometimes the drill holes aren’t perfectly aligned or the wood can be slightly warped. Maybe the frame of the shelving unit isn’t completely straight, causing the holes to be off angle. Have you checked if the shelf is standing perfectly level and if the side panels have any slight misalignment? Sometimes a little adjustment of the side panels before inserting the shelves can help. These small inaccuracies can be annoying, but there’s usually a solution—don’t get discouraged!
tolokau
13 Dec 2021 18:11
I will provide a clear, step-by-step explanation on how to assemble BILLY shelves with shelves, especially if they don’t fit perfectly at first.
1. First, check whether the rows of holes on both sides are exactly parallel and equally spaced. Even small deviations can make the shelves difficult to fit.
2. Inspect the dowels or fittings used. IKEA usually uses plastic fittings, which can easily become deformed. If you have multiple sets, compare them for any damage.
3. Make sure the shelves are not twisted or inserted with the wrong side. Often, there is a side-specific edge or a special groove.
4. Never use force to fit a shelf; instead, double-check the alignment. If needed, you can carefully sand or file small uneven spots.
5. Ensure you haven’t stripped the screw holes, as this can worsen the fit.
In summary: common issues are slightly warped side panels, damaged fittings, or incorrect placement of the shelves. A systematic approach helps resolve these problems.
neoren
13 Dec 2021 18:27
Have you checked whether the shelves are actually the original ones for the BILLY bookcase? Often, shelves from similar versions do not fit exactly.
Also, sometimes the drill holes are slightly off, so make sure the bookcase is standing square. Using a spirit level helps with alignment.
FELOTAU
13 Dec 2021 18:43
neoren schrieb:
Sometimes the drill holes are slightly misaligned
Yes, that’s exactly what I mean – it almost feels random at times. IKEA is generally reliable, but with large production runs, small issues can occur during manufacturing, which is normal.
I wonder if you could discuss it with customer service. Maybe it’s a known issue? Asking politely might help.
ANMARCOS
14 Dec 2021 09:12
I think we often regard IKEA furniture too much as "mass-produced goods." Of course, mass production can lead to some inaccuracies, but BILLY has been on the market for decades, and the model has actually proven itself.
In my opinion, the issue is not the manufacturing, but the expectations. The shelving system is designed for light loads, not for millimeter-precise fits. If the shelf is placed completely level or the brackets are inserted perfectly, these problems rarely occur.
Perhaps the problem is more that some users expect everything to fit exactly like in the CAD model. However, the parts are made of particleboard with a foil covering, where slight misalignments are possible.
I believe more patience and minor adjustments during assembly will solve this.
