ᐅ Why do some BILLY shelves not fit properly into the bookcase?
Created on: 25 Mar 2022 19:27
ertan67
ertan67
25 Mar 2022 19:27
Hello everyone, I have encountered a problem while assembling my new BILLY shelf that I’m sure many people know: some BILLY shelves simply don’t fit properly into the designated rails or supports within the unit.
I used the correct shelf dimensions and checked the numbers accordingly. However, the shelves either fit too tightly or cannot be fully slid in, often getting stuck on one side.
I’m interested in understanding the causes of this and whether there are known reasons why BILLY shelves sometimes don’t fit perfectly into the unit, even though everything should be compatible. Could it be due to manufacturing tolerances, batch variations, or is it often related to the assembly process?
I look forward to your experiences and tips on how to better understand or avoid this issue.
klo40
25 Mar 2022 20:03
Hello ertan67,
I am very familiar with the issue regarding BILLY shelves and would be happy to give you a detailed explanation.
First of all, you should be aware that IKEA products sometimes have manufacturing tolerances of up to a few millimeters, meaning the shelves and the unit itself are not always made to exact millimeter precision. In particular, I have often noticed that BILLY wooden shelves are cut slightly unevenly or may swell a bit due to moisture.
ertan67 schrieb:
Some BILLY shelves simply don’t fit into the designated rails or holders in the unit.
This can also be caused by the rails used: in older or some models, the rails made of metal or plastic may be slightly bent or installed too tightly. So first check whether the rails are straight and properly hooked in.
If you have shelves from other BILLY units (e.g., older versions), they might not fit due to slightly different widths or thicknesses—over the years, IKEA has sometimes adjusted the standards.
My advice:
1. Use a knife or fine sandpaper to check if the edges of the shelves have rough spots or burrs that can be carefully removed.
2. Check that the holders fit securely and are aligned straight.
3. Sometimes lightly oiling or sanding the edges can help achieve a better fit.
In summary: these problems usually occur due to small manufacturing tolerances, material expansion (e.g., from moisture), and imperfect installation of the rails.
I hope this helps you!
Ethan
26 Mar 2022 07:52
I’d also like to contribute to this topic, especially since I recently had a similar issue with my BILLY shelf and did a lot of research.
First, a small addition to what has already been said:
klo40 schrieb:
Manufacturing tolerances of up to a few millimeters and material expansion can be problematic.
This is definitely an important point. It’s also crucial to note that the shelves often have an internal grain structure that can react very differently to moisture—for example, in spring after rain or with dry heated air. This causes the shelves to slightly swell or shrink, making them no longer fit neatly into the supports.
Additionally, I noticed that BILLY shelves can sometimes vary in thickness, even if they are from the same series. If you have multiple shelves, it’s worth measuring and comparing them carefully, not only the width but also the height or thickness.
What helped me was lightly sanding the shelves (especially the edges) so they have a bit of clearance when sliding in. However, be careful not to remove too much material.
One more general tip for inserting the shelves: tilting them slightly when sliding them in often helps, especially if the unit is a bit warped due to tension. Then the shelf fits much more easily into its intended place.
I hope this is helpful—everyone struggles with this small inaccuracy at some point; it’s quite common with IKEA.
MUMENAR
27 Mar 2022 11:14
First of all, thanks to everyone for the helpful answers so far.
However, I would like to raise a critical question: There is frequent mention of "manufacturing tolerances" and "material expansion," which is certainly plausible. But I wonder if these alone can truly explain why so many users experience the exact same issue.
ertan67 schrieb:
I would be interested to know what the causes are and whether there are known reasons why, in particular, BILLY shelves sometimes do not fit perfectly into the unit, even though everything should be compatible?
I suspect that there might be a systematic design or quality issue here: It could be that the stated dimensions of the shelves and rails are nominally the same, but they were not ideally matched during design, resulting in assembly tolerances that are too tight.
One theory is that IKEA operates with optimized tolerances and production costs that are right at the limit of what can be fitted precisely. As a result, fitting issues inevitably occur when there is even a slight deviation.
Furthermore, it would be interesting to know if there are variations in production (e.g., different factories, production batches) that deliver better or worse quality.
My suggestion to the community: If anyone has reliable data or experience from quality control or evidence-based insights, please share. I consider the explanation of "material expansion" alone insufficient to fully explain the phenomenon.
