ᐅ Why do some BILLY replacement parts no longer fit older models?
Created on: 5 Jan 2021 14:07
Sarueli
Sarueli
5 Jan 2021 14:07
I have noticed for some time that certain replacement parts for the popular Billy shelf from IKEA no longer fit older models, even though they are supposed to be compatible according to the description. Specifically, I’m referring to the back panels and shelves, which have not fit exactly since the purchase year 2008. Does anyone have an idea what could be the reasons for this incompatibility? Could it be due to changes in dimensions, material thickness, or construction? I am especially interested in whether IKEA deliberately made changes to the parts that limit compatibility with older models, or if there are other technical or manufacturing reasons.
I look forward to your assessments and explanations!
ritotar
5 Jan 2021 14:39
Hey Sarueli :-)
This is a really interesting topic. From my experience, manufacturers like IKEA regularly optimize their products, even those that seem unchanged at first glance – like the classic BILLY bookshelf. The dimensions usually stay almost the same, but small changes are introduced: for example, the thickness of the particleboards, the type of joints, or improved back panels designed to be more stable.
Sarueli schrieb:
whether IKEA has intentionally made changes to parts that limit compatibility with older models
I believe these adjustments are not necessarily made to exclude older models – that would be counterproductive – but rather to improve manufacturing processes or reduce material costs. Unfortunately, this sometimes results in spare parts no longer fitting 100% perfectly.
Domau0
6 Jan 2021 07:22
Good morning,
to accurately understand the technical issue, one should look at the design changes IKEA has made to the BILLY shelving unit. From 1979 until today, there have been several versions, particularly with variations in the thickness of the particleboard, originally 16mm (0.63 inches) and later 15mm (0.59 inches), or vice versa. This slight difference can already cause replacement shelves and back panels to no longer fit perfectly, as the tongue and groove connections are designed for a specific thickness.
In addition, the attachment points have been altered—for example, the drilled holes for dowels and nails in the back panel have been shifted in some places. This means a back panel from 2020 will not mechanically fit on a shelf from 2008 because it simply doesn't line up with the dowels or nails.
ritotar schrieb:
most of the time, material thicknesses or connections are optimized
That’s exactly right. As a non-expert, you might not notice this, but every manufacturing change can affect compatibility.
Another reason is that IKEA sometimes “updates” certain shelves to reduce weight and increase sustainability by using different types of wood or Smart-Board materials. These often have slightly different properties in terms of dimensions or flexibility.
BLAKEO
6 Jan 2021 09:58
I think it is important not only to focus on technical details but also to question the manufacturer’s strategy. Why would IKEA allow spare parts to become incompatible if it harms the customer?
Sarueli schrieb:
Does anyone have an idea what might be the reasons for this incompatibility?
According to my analysis, the cause is a combination of several factors, including production optimizations, logistics, and the attempt to reduce costs through adjusted materials. The fact that they are currently paying less attention to legacy compatibility is unfortunate from the customer’s perspective.
I don’t see this as intentional wrongdoing but as a side effect of an efficiency-driven system. But what if IKEA instead offered modular spare parts specifically for older models? That would be a smart business model.
Does anyone here in the forum know if there is any official information from IKEA on this?
Ryder35
6 Jan 2021 12:14
In short: Different materials and slightly altered dimensions cause newer parts to no longer fit. Since IKEA frequently makes small changes, these compatibility issues arise.
Spare parts should always be ordered according to the model year.
LOJOPAR
6 Jan 2021 18:47
Hello Sarueli,
I would like to add some structure to the previous posts:
1. Dimensions and Tolerances: As already mentioned, changes in the thickness or width of parts have significant effects on the fit. The joints (grooves, drill holes, dowels) are precisely dimensioned, and small deviations lead to improper fit.
2. Material Quality and Construction: Newer models use different particle boards or engineered wood products, which are sometimes narrower or thinner. Adhesives and coating types may also have changed, causing slight dimensional changes or expansion issues.
3. Manufacturing Processes: Production has become standardized, automated, and more efficient, sometimes resulting in adjustments that exclude older components.
4. Design Changes: Since the introduction of the BILLY shelf, functional details have occasionally been modified (e.g., back panel fixings, number of drill holes, frame profiles).
My advice: If replacement parts are needed, it is important to find out the exact production year and carefully compare the part numbers.
If you have questions about a specific replacement part, I am happy to help!
