ᐅ Why doesn’t assembling the Malm bed always work on the first try?
Created on: 11 Aug 2021 09:17
soludo
Good morning everyone,
I am currently facing the issue that assembling the Malm bed frame does not always go smoothly on the first try. I am wondering what the exact cause might be, since even though I strictly follow the instructions, there are often minor hiccups such as misaligned screws, unclear fittings, or similar problems.
Does anyone have experience with why assembling this particular model often only works after multiple attempts? Could it be due to the assembly instructions, the quality of the parts, or perhaps unexpected tolerances?
I would appreciate a detailed explanation, preferably with tips on how to avoid common sources of errors from the very beginning.
Thank you for your detailed responses. To summarize:
- Dimensional tolerances and minor manufacturing variations can make fitting components challenging.
- Instructions are often not completely clear, which can lead to misinterpretations.
- The assembly environment and choice of tools also have an impact.
- Material quality and component defects should be checked before construction begins.
I have one more question, specifically about the instructions:
Do you have any examples where certain steps are too vague or could be misunderstood?
This would help to better understand the instructions or suggest possible improvements.
soludo schrieb:
Do you have examples where certain steps are too vague or could be misunderstood?Yes, for example, the labeling of screw types is often poor or completely missing on the individual parts. This makes it necessary to guess which screw is actually meant. The labeling of the components themselves is sometimes done in a similar way, which complicates the selection.
Another example is the guidance on how deep to drive the screws – this is more of a rough recommendation than an exact value. In practice, this often leads to having to redo the work three times.
Additionally, I can add that the lack of numbering or color coding for dowels and screws often leads to confusion.
Furthermore, the reverse is not always clear: If something doesn’t fit, you should check whether it might be installed in the wrong place. The instructions could be clearer here with alternative illustrations or warning notes.
Ianlau schrieb:I have felt the same with some IKEA instructions and consider it a real drawback.
You then have to guess which exact screw is meant
A technical note regarding fittings: the components are often made of particleboard with a melamine coating. These materials can easily expand or change due to moisture, which is especially critical with tight fittings.
The instructions assume that all panels are perfectly flat. However, this ideal is not always achieved in practice, which can make inserting some connectors difficult.
My advice: before final assembly and screwing, always loosely fit and align all parts first. This way, problematic areas can be identified and corrected before tightening the screws permanently.
