I have a somewhat unusual question that has been bothering me recently regarding my Malm bed from IKEA: Why does the Malm bed only squeak occasionally and not all the time?
The construction is quite simple – wooden frame, slatted base, screws – but the squeaking occurs irregularly, sometimes not at all, and sometimes it’s very annoying. I have already tried tightening the screws and placing the bed on a firm surface. Still, the noise sometimes comes back without me making any changes to the bed.
I’m especially interested in the mechanisms behind this intermittent squeaking: Could it be due to material tensions, moisture, temperature, or perhaps humidity? Possibly movement or even the mattress play a role?
Does anyone have experience or deeper knowledge why a basically stable bed frame would make noises only sporadically?
I look forward to your insights and explanations!
PeoDaniel14 Apr 2024 08:46Additionally, I would like to point out that the subfloor can also play a role:
An uneven floor leads to slight movements in the bed frame. This causes stresses in the structure, which can sometimes result in squeaking noises.
If possible, adjust the leveling feet or place small wooden shims underneath to increase stability.
Exactly, regular maintenance is often underestimated but very effective.
gasidney schrieb:
Regularly tightening the screws every few weeks usually prevents this.
Here is a summary of what we have so far:
- Intermittent squeaking is caused by changing friction conditions between the wood and the joints
- Stress from temperature and humidity fluctuations temporarily alters the connections
- Movements and load changes lead to varying points of stress
- The slatted frame can also be a source of the issue
- The underlying surface may cause minimal movements that contribute to squeaking sounds
Regularly checking your bed, tightening screws, and possibly using felt tape usually helps control the squeaking.
If the problem persists stubbornly, considering replacement parts or a different slatted frame may be worthwhile.
Great thread, I have a Malm bed myself and can confirm: you just have to love it when it shows its little quirks. A bit like a good old friend who never quite stays still 😉
But seriously: regular inspection, lubrication, and keeping the bedroom environment stable – then it will be quiet.
And if none of that helps, maybe just a night with earplugs will do the trick ;-)
