ᐅ What to Do About Squeaking Noises in the Malm Bed?
Created on: 30 Mar 2021 19:43
sinpau
Hello everyone, I have a problem with my Malm bed from IKEA: it keeps squeaking whenever I move or turn around. It’s quite annoying and affects the comfort of my sleep. I’ve done a bit of research and found out that squeaking often comes from loose joints or the slatted frame. Since I bought the bed only about a year ago, I’m a bit surprised by this. Can someone explain how I can identify the exact cause, what the typical sources of these squeaking noises are, and what I can do to eliminate them permanently? Maybe the tip about lubricants could help? I would appreciate detailed advice because I’d like to fix it myself without having to call someone. Thanks in advance!
bulanau
31 Mar 2021 07:12
Hello sinpau, here is a brief guide on how to systematically identify the causes:
1. Check screws: As you have already done, inspect and tighten all screws on the frame.
2. Inspect the slatted base: Metal slatted bases often squeak at the connection points. Tightening helps, and if needed, use fine sandpaper on the contact areas to remove rust or rough spots.
3. Lubricants: For metal connections, I recommend a dry lubricant like graphite powder or silicone spray, since oil tends to attract dirt.
4. Wood joints: Baby powder is often better than oil here because oil can cause the wood to swell.
5. Check load: If individual slats are too loose, replacing them can actually be useful.
I have lubricated slatted bases several times and experienced significantly less noise afterward. Important: use lubricants sparingly and always test whether the noise disappears.
If you want, I can also give you some tips on how to remove and properly clean the slatted base.
sinpau
31 Mar 2021 07:45
bulanau schrieb:
Check the slatted frame: Metal slatted frames often squeak at the metal joints.
Thanks, that makes sense to me. Mine is actually a metal slatted frame, not a wooden one.
bulanau schrieb:
For metal connections, I recommend a dry lubricant like graphite powder or silicone spray, as oil attracts dirt.
Is there a negative reaction between baby powder and metal joints? Can they be combined in any way if the frame is wooden? Or should baby powder be avoided altogether if metal parts are involved?
roryvin
31 Mar 2021 08:19
Baby powder is effective for dry contact points on wood but is not recommended for metal joints. For metal, it is better to use a dry lubricant, such as graphite powder or silicone spray. Both help reduce squeaking by lowering friction.
Never use oil, as it attracts dirt and contaminates the mechanism. Metal parts can be improved by gently cleaning with alcohol and allowing them to dry before applying lubricant.
Summary:
- Wood: baby powder or furniture wax
- Metal: dry lubricant (graphite/silicone)
This helps keep the mechanism and materials in good condition and reduces squeaking.
Joe52
31 Mar 2021 09:07
I really like how detailed your explanation is! 🙂 I had the same problem with my Malm bed squeaking, and what helped me was tightening the screws properly and then applying baby powder to all the contact points.
But it really requires patience, because sometimes the squeaking only stops after a few days once everything has settled. For me, the combination of tightening and powder worked much better than any sprays.
Think of it as a small “maintenance” for the bed that’s worth doing and can give you a better sleeping experience in the end. 🙂
paulu
31 Mar 2021 12:31
A quick note: Also check the connection between the headboard and footboard, and whether any metal brackets on the frame are firmly secured. These are often the source of squeaking sounds. If screws do not hold properly, sometimes using wooden dowels or screws with a larger diameter can help.
For slatted bed bases, silicone spray or graphite can reduce metal friction. Treat wood with baby powder. Good luck!
