ᐅ Why does the IKEA Brimnes bed sometimes squeak during use?
Created on: 30 Jun 2023 08:17
martinli
martinli
30 Jun 2023 08:17
I have an IKEA Brimnes bed, and I’ve noticed that it sometimes squeaks when I move around or simply lie down. The noise doesn’t occur constantly but rather occasionally, especially when moving on certain parts of the bed. It’s an annoying, disturbing squeak that can affect sleep quality.
I would like to understand why the Brimnes bed makes this squeaking noise. Could it be due to the design, the materials, or the assembly? Are there known weak points regarding the construction or the components used? I’ve heard that wooden beds in general can often make noises when screws loosen or because of friction between the individual parts.
I’m also interested in how to best eliminate or prevent the squeaking. Should the screws be tightened regularly? Or are there specific maintenance or care tips for this model?
Thanks in advance for your help and technical advice!
Gafiel
30 Jun 2023 10:42
Hello martinli,
First of all, your clear and well-thought-out question is very helpful for troubleshooting. The squeaking in your IKEA Brimnes bed is usually due to mechanical friction. The bed is mainly made of assembled wood-based panels such as particleboard, which are prone to slight movements within the frame.
The following basics are relevant:
- The joints consist of particleboard and metal fittings. Over time, these can settle slightly, especially if the screws are not fully tightened.
- Temperature and humidity fluctuations cause minimal expansion or contraction of the wood, which can lead to loosened joints or gaps.
- Movements on the sleeping surface transfer forces to the fasteners and can trigger creaking or squeaking.
The squeaking usually arises from friction between:
- Wood on wood (e.g., at the side panels or crossbeams)
- Wood on metal (especially at metal brackets or screw heads)
I recommend systematically following these steps:
1. Tighten all screws and connections of the bed with the appropriate tools, paying attention to the correct torque to avoid damaging the material.
2. Check whether any wooden parts show cracks or wear that could encourage movement.
3. Treat wooden slats or support surfaces sparingly with a suitable lubricant (e.g., wax or silicone spray) to reduce friction.
4. Inspect the slatted frame separately for squeaky spots, as it is often the source of noise itself.
I have one more question: Does the noise occur more when pressure is applied at the foot or head end, or is it independent of the area? This can help a lot with pinpointing the cause.
In summary: Squeaking is a common issue with wood joints and often results from loose screws and slight material movement. With regular maintenance and small measures, it can usually be significantly reduced or eliminated.
Elodie
30 Jun 2023 12:05
I understand your problem, martinli – that kind of squeaking can really ruin the cozy evening atmosphere! 😄
Gafiel schrieb:
Treat wooden slats or contact surfaces with a suitable lubricant (e.g., wax or silicone spray, applied very sparingly) to reduce friction.
I can only agree with that advice, but be careful: don’t use too much liquid, or the entire slatted frame will suddenly become slippery, turning the bed into a mini ski slope! 😅 It’s better to apply it sparingly and only where needed.
Speaking of humidity: in our bedroom, the air often fluctuates with the weather, and sometimes the squeaking increases in the morning, which I then fix with a brief, firm tightening of the screws.
One more tip: try to locate the exact squeaking spots by gently rocking the bed – sometimes it’s just a small wood splinter rubbing in the wrong place.
I hope you find the culprit soon and can enjoy quiet, peaceful sleep again!
joro10
30 Jun 2023 13:51
Tighten the screws, check the slatted frame, and if necessary, place padding between the wooden joints. That helped me.
Nathanaelk
1 Jul 2023 07:28
I agree with Gafiel’s analysis but would like to go into more detail.
The Brimnes bed is modular, meaning it is not a solid block but consists of several parts, mostly held together with metal fittings and tension connectors. A frequently underestimated aspect is the elasticity of these fittings combined with the moisture absorption of the particleboard panels. These materials react to changes in the environment with slight movements, which can cause noises.
Particularly affected are:
- The joints between the headboard, footboard, and side panels
- The support areas of the slatted frames within the bed frame
- Attachment points under weight stress
My recommendations:
- Fine-tune the screws in the order from inside to outside
- Check for minimal damage to the threaded inserts
- Use thin felt or plastic pads at friction points to reduce noise and abrasion
It would be interesting to know how long the bed has been in use and whether you have noticed any changes in squeaking depending on the season or room climate. Also, whether you use a mattress type that increases surface flexing (e.g., spring mattress versus cold foam).
Siflo
1 Jul 2023 09:46
In summary, from technical and functional perspectives:
- The squeaking mainly occurs due to slight movements between wooden and metal parts.
- It is often caused by loose connections that develop over time and with use.
- Moisture and temperature changes increase material movement.
Recommended approach:
- Carefully check and tighten screws
- Use foam tapes or felt strips for cushioning
- Inspect the slatted frame for fit and seating
Regular preventive checks of the fastenings are advisable to avoid squeaking. This issue is generally known in beds with similar construction and material choices.
