I have an IKEA Brimnes bed, and I’ve noticed that it sometimes squeaks when I move around or simply lie down. The noise doesn’t occur constantly but rather occasionally, especially when moving on certain parts of the bed. It’s an annoying, disturbing squeak that can affect sleep quality.
I would like to understand why the Brimnes bed makes this squeaking noise. Could it be due to the design, the materials, or the assembly? Are there known weak points regarding the construction or the components used? I’ve heard that wooden beds in general can often make noises when screws loosen or because of friction between the individual parts.
I’m also interested in how to best eliminate or prevent the squeaking. Should the screws be tightened regularly? Or are there specific maintenance or care tips for this model?
Thanks in advance for your help and technical advice!
martinli schrieb:
It is an annoying, disturbing squeaking that can affect sleep quality.The squeaking is indeed a common issue with wooden bed frames like the Brimnes.
The noise is caused by the interlocking wooden parts rubbing against each other due to slight movements and stresses. IKEA models in this price range typically use particleboard and composite materials that respond to changes in the environment.
A key step to fix this is carefully checking all joints for looseness. Mechanical dampers or pads made of rubber or felt between stressed components can also be helpful.
In my personal experience, regular maintenance (every six months) can minimize or eliminate the squeaking.
