ᐅ Why does my Billy bookcase wobble even though it is securely attached to the wall?
Created on: 31 Aug 2021 19:12
leosar
Hello everyone, a few days ago I mounted my Billy shelf to the wall, using all the supplied plugs and screws, and made sure the wall mounting was installed correctly. However, the shelf still wobbles noticeably, especially when I make slight movements on the top shelf board or open the door. It doesn’t seem to be the wood itself, which is stable, and the screws are tight. The mounting points are fixed into solid spots in the wall (concrete).
Does anyone have an idea why the shelf might wobble despite a solid wall fixing? Are there common installation mistakes I might have overlooked, or is this possibly normal for this model? I’m looking forward to your assessments and especially practical solutions.
SauDietmar
1 Sep 2021 09:15
A brief tutorial to help everyone understand what affects stability:
A typical Billy shelf unit has the following weak points:
- Mounting height: Screws should be placed as close as possible to the top edge to reduce tipping forces.
- Floor contact: If the floor is uneven or the base is damaged, there can be wobbling. Adjusting leveling feet (if available) or using shims can help here.
- Back panel: The thin back panel stabilizes the unit. If it is loose or damaged, the entire structure becomes unstable.
Conclusion: Check these three points first; this usually helps very effectively.
leosar
1 Sep 2021 10:05
Thank you for your quick and detailed responses!
During installation, I made sure to work on a solid, level surface, and the screws were tightened with the appropriate torque. The back panel is intact and sits completely flat. Two screws are fixed into the wall, both anchored in concrete.
EDWARD0 schrieb:
"Check if the shelf is sitting fully flat on the floor."
I’m confident the floor is very even.
LOJOPAR schrieb:
"Are your wall plugs properly sized? For concrete, there are special high-load nylon or metal anchors."
The wall plugs are original IKEA, but they are plastic, not metal anchors.
I’m wondering if the two attachment points are sufficient, or if I should add a third screw at the top?
Could it be that the individual adjustable shelves reduce stability if they flex slightly under load?
I’d appreciate any further advice.
TELAHAU
1 Sep 2021 12:48
It is unlikely that the shelf itself is the problem if the wood feels sturdy. However, two fixing points are often not enough, especially for taller shelves. Adding a third screw at the top usually helps to prevent wobbling.
Plastic wall plugs are generally sufficient in concrete, provided they are properly installed and inserted deep enough.
Joshbe
1 Sep 2021 13:15
leosar schrieb:
"The anchors are original IKEA, but not metal anchors, rather plastic ones."
This is generally acceptable for normal loads, provided the plastic anchors are properly sized. Two mounting points are often minimal.
Adding another quarter-inch screw near the top, positioned centrally, helps prevent the shelf from tilting forward like a lever. It is also important to tighten screws and anchors firmly, but without overtightening the wood.
The advice to check the back panel is good. Ideally, it provides lateral stiffness to prevent wobbling.
meGreg
1 Sep 2021 18:58
Just a little anecdote: I once thought my Billy shelf was wobbling despite all the fastenings—until I realized the floor was slightly uneven, causing the shelf to barely hover at the back. I just slipped a piece of rubber underneath, and since then, no more problems! 😄
So maybe just double-check all the support points; sometimes the wobble isn’t where you first expect it.
And yes, adding one more screw at the top definitely saves some headaches! 😉
LOJOPAR
2 Sep 2021 07:34
One more addition on the topic of back panels:
In a typical Billy bookshelf, the back panel is only about 3mm (0.1 inch) thick and is attached with small nails. In older or improperly nailed back panels, stability can be significantly reduced.
A small but often underestimated detail is to reinforce the back panel with additional small screws or mounting tape. This provides better lateral stiffness and noticeably reduces wobbling.
I also recommend, if available, using corner brackets at the top, fixed between the shelf and the wall. These greatly enhance stability.
