ᐅ Why do the doors on some Billy bookcases occasionally stick?
Created on: 13 Jan 2019 08:37
jaden8
jaden8
13 Jan 2019 08:37
I have a question that has been on my mind for a while: Why do the doors on some Billy bookcases occasionally stick?
I have noticed that this doesn’t happen with all Billy bookcases, but rather sporadically with certain units or even just individual doors within the same series. The doors then don’t close properly, catch when opening, or sometimes only close with some effort. I am especially interested in whether this is due to manufacturing, assembly, or possibly environmental factors like humidity or floor conditions that could cause this behavior.
Technical aspects such as the materials used, hinges, and their adjustment are also relevant to me. Who has had similar experiences or can explain this issue? Are there proven solutions to get the doors to close smoothly and without resistance again?
Thanks in advance for your insights!
danial60
13 Jan 2019 10:22
Hello jaden8,
Your question is very well formulated and already takes many possible causes into account.
The occasional sticking of the doors on Billy bookcases can usually be traced back to two main technical factors: firstly, manufacturing tolerances and secondly, the accuracy of on-site assembly.
IKEA produces large quantities, which means minor dimensional deviations can occur. These small inaccuracies can cause the doors to not always fit exactly as intended. The drilling holes and hinge attachments are especially relevant here. If the hinges are not adjusted correctly, whether due to misalignment during installation or subsequent warping, friction can easily develop.
Another factor is the material used: With wooden furniture like Billy, fluctuations in humidity cause the wood to move. Slight swelling or shrinking in the material—especially on door panels and edges—can change the gap, causing the doors to stick. Extended storage in damp rooms or a completely new location with higher humidity levels can worsen the issue.
Finally, you should also consider the floor: An uneven surface can cause slight deformation or tilting of the bookcase. As a result, the hinges are under stress, making opening and closing more difficult.
Have you checked whether the doors themselves are warping or if the floor might be uneven? A close inspection of the hinge attachments could also help. If you can adjust the hinges slightly, as described in the assembly instructions, this could already lead to a significant improvement.
V
vinicius44
13 Jan 2019 11:45
Briefly adding to Danial’s very detailed post:
The doors of Billy bookcases often hang on the adjustable hinges Ikea uses. These are designed to allow some flexibility to compensate for unevenness.
danial60 schrieb:
If the hinges are not properly adjusted, whether due to misalignment during installation or later warping, friction can easily occur.
That is the core of the problem. I would recommend always checking the tilt and height adjustment of the hinges first on doors that stick, and readjusting if necessary. Usually, a small correction is enough to optimize the door gap and eliminate sticking.
It can also help to completely remove the door and rehang it precisely—a step that is often underestimated.
putan
14 Jan 2019 07:59
I can also confirm this from my own experience – one of my Billy shelves actually got stuck so badly that I almost felt like the shelf was trying to annoy me. 🙂
danial60 schrieb:
Another point is the material used: With wooden furniture like Billy, fluctuations in humidity cause the wood to expand and contract.
I can only agree with that. In winter, when the heating is on and the air is drier, the sticking didn’t happen at all. But especially in humid summers or during transitional seasons, when the humidity is high, the wood would expand slightly and then the door became harder to open.
A little tip from me: sometimes just oiling the hinges a bit is enough – not too much! Just a drop on the moving parts makes the mechanism run more smoothly.
A little patience with the old Billy, it just needs some care too 😉.
BLAKEO
15 Jan 2019 09:12
Interesting contributions so far – however, I also see another aspect that is often overlooked: the impact of external forces and the resulting deformations.
vinicius44 schrieb:
I would recommend always checking the hinge’s pivot and height adjustments first when dealing with sticking doors, and readjusting if necessary.
While that can be quickly adjusted, what if the frame structure itself is slightly twisted? Especially with large Billy-style shelves that are fully loaded, uneven loads can occur. This causes the furniture to distort, which can lead to sticking even if the hinges are correctly adjusted.
Furthermore, the quality or condition of the hinges themselves should also be considered – with frequent use, they can wear out or become stiff, which worsens the problem.
I would suggest checking whether the shelf is level and shows no visible warping, and if in doubt, to observe the maximum load capacity to avoid mechanical deformation. A permanent solution should either stabilize the shelf (e.g., with wall anchors) or replace individual hinges if they are worn.
