ᐅ Why do some Billy bookcases warp during the summer?
Created on: 3 Sep 2024 08:23
Rodra
I have been wondering why some Billy bookcases tend to warp so much, especially in the summer. I noticed that with rising temperatures and higher humidity, the doors or side panels often warp, causing them not to close properly or making the furniture feel somewhat unstable.
It seems to be related not only to the material but also to the craftsmanship, as not every Billy bookcase is affected. Could this be connected to the type of particle board used or the surface finish?
Does anyone have experience or technical explanations as to why these deformations occur mainly during warm months? Is moisture absorption in the material underestimated, or do physical properties like wood swelling play a key role?
I look forward to hearing your insights and tips on how to prevent or at least minimize this warping.
Paunon
5 Sep 2024 08:16
One should be careful not to place Billy shelves in damp rooms. Direct sunlight on the surface can also raise the temperature and cause the material to swell.
KNUTGI schrieb:
"Anti-swelling agents for wood can help"
That is a good suggestion. Such agents reduce water absorption.
Maria35
5 Sep 2024 16:44
In summary:
The warping of Billy shelves in summer is a common technical issue caused by the interaction of materials (particleboard with laminate), processing (edge sealing), and the environment (humidity, temperature).
gasidney schrieb:
"Ensure stable humidity levels"
This advice is absolutely correct. Climate control is the most effective solution; using a humidifier or dehumidifier in the room helps maintain constant conditions.
Although Billy offers excellent value for money, one should not expect miracles from particleboard furniture. The deformations are usually small but noticeable and annoying.
Those who want to avoid warping should take proper care of the furniture and follow the recommendations described.
