Lately, I've noticed that the IKEA Malm nightstands often start to wobble, which honestly is quite annoying. I'm wondering what the typical causes for this are. Is it due to the design, the workmanship, or more related to the assembly?
I'm especially interested in whether the wobbling is a common characteristic of these pieces of furniture or if it mostly results from user errors or mistakes during setup.
Can someone explain the mechanics behind why the Malm series is so often affected and what can be done to prevent or reduce the wobbling?
Thanks in advance for any helpful responses!
From a technical perspective, the wobbling of Malm nightstands is not a design flaw but a result of the materials used and the design aimed at cost-effective production.
Particleboard with pressed joints is not ideal for high structural loads. This causes screw connections, in particular, to develop slight play over time.
Precise assembly is crucial, as is the use of washers on the screws, which can improve pressure distribution.
It is also recommended to check the surface on which the nightstand stands, as even small unevenness can significantly affect overall stability.
To improve stability, additional reinforcements can be attached to the corners of the nightstand to prevent tipping.
Thank you for the responses so far, especially the detailed contributions from LOGEMIN and Nabla64, which have been very helpful to better understand the issue.
I’m interested to know if there are any official recommendations or accessories from IKEA to specifically reduce wobbling in Malm nightstands? Or perhaps there are known upgrades that improve stability?
Otherwise, I will try tightening the screws and using the felt pads that were recommended here.
Regarding IKEA accessories:
IKEA generally does not offer specific reinforcements or upgrade kits for Malm nightstands. However, universal corner brackets or furniture connectors, available at hardware stores, can be easily installed to improve lateral stability.
If there is significant wobbling, it is advisable to check the back panel. This is often made of thin material and provides bracing for Malm models. If it is loose or deformed, additional support can be added later with screws or nails.
Tip: When tightening screws, always use a cross pattern to avoid overstressing and minimize any play.
A brief update from me: Yesterday, I checked all the screws and tightened them in a crisscross pattern, then attached felt pads under the legs. After that, the bedside table was noticeably more stable and barely wobbles anymore.
Thank you very much for the tips! This confirms my suspicion that the wobbling is mainly caused by assembly, usage, and the environment rather than fundamental design flaws.
