ᐅ Why do Malm drawers often become misaligned?
Created on: 29 Apr 2022 08:13
govalent54
Why do Malm drawers often become misaligned? I have noticed that with many pieces from this series, the drawers gradually tilt over time, which makes them harder to operate and looks unattractive. I am curious whether this is due to the material quality, the design, or the installation. Environmental factors such as humidity or uneven loading might also play a role. Has anyone investigated this issue in detail or gained practical experience with it? I would also like to know how to effectively fix the problem without having to replace the entire drawer.
Leonardteo
1 May 2022 09:47
I would like to add some technical details here that are often overlooked: The construction of Malm drawers is based on a simple tongue-and-groove joint between the side panels and the drawer bottom, secured by screws on the side walls. Due to material expansion, especially with chipboard or MDF, these joints can become loose or warped over time, leading to misalignment.
Additionally, the plastic drawer slides have small gear-like grooves that may no longer engage precisely under load and with dirt accumulation, causing asymmetries in the sliding mechanism.
A thorough inspection and, if necessary, cleaning, lubrication, or replacement of the drawer slides is recommended. Using thread-locking adhesive on the joints is also advisable to prevent loosening.
The effects of storage conditions and humidity on the furniture panels should not be underestimated, as the problem can worsen during more humid seasons.
Deoma
2 May 2022 15:29
Often misaligned because the guide rails made of plastic bend. Tightening the screws and replacing the rails will fix this.
Jodyro
3 May 2022 17:06
Simply put: Drawers become misaligned when screws loosen or runners bend. The solution: adjust, tighten screws, or replace the runner. It’s quick and lasts a long time.
