ᐅ Why do Malm drawers sometimes get stuck for no apparent reason?
Created on: 18 Feb 2022 09:12
georgsin
I have a rather specific problem that I haven’t been able to find much clarity on so far: “Why do Malm drawers stick without any obvious reason?”
I own several Malm dressers from IKEA, all relatively new with no significant signs of wear, but their drawers frequently stick. There is no visible damage or warping, and the drawer slides all appear to be in perfect condition. This happens regardless of whether the drawer is fully loaded or nearly empty.
I am particularly interested in what factors, despite everything appearing to be in order and correctly assembled, could cause this sticking. Is it due to the design? The materials? Temperature or humidity influences? Or perhaps something entirely different?
Maybe someone here has noticed similar issues or understands the technical background that could help prevent or fix this sticking without having to disassemble the entire drawer.
I look forward to your insights and experiences!
Z
zarHenning18 Feb 2022 13:17Material expansion and installation errors are the main causes.
Particleboard drawers swell when exposed to moisture, and even slight misalignments can cause them to stick.
Handle: Remove the drawer, clean the runners, tighten the screws, and apply a light lubricant.
I agree with that, I had the same problem. After cleaning the tracks and slightly adjusting the screws, the drawers now slide smoothly again.
And yes, sometimes wood can expand with moisture – my bathroom was the culprit. Since I moved the dresser to the living room, I haven’t had any issues anymore. 😉
It is also important to know that Malm drawers are not designed with tolerances in the millimeter range, as is common with higher-quality furniture.
In my experience, the drawer frames are relatively thin, which promotes warping. Additionally, the coating is often prone to minor damage that can cause swelling at the edges.
A systematic check for cabinet warping and slight readjustment of the drawer slides can resolve many sticking issues.
anken schrieb:
Assembly errors, for example a slightly crooked screw or uneven spacing to the cabinet wallThank you for this note, I had not explicitly considered that before. I will carefully inspect the assembly again, paying particular attention to the screws and the positioning of the sliding rails.
FEKAU schrieb:
Targeted maintenance or readjustment recommended, for example tightening screws, cleaning and lightly lubricating the railsCleaning and lubricating the sliding rails sounds reasonable. Are there any recommendations on which lubricants are suitable to avoid damaging the rails?
Gino38 schrieb:
Malm drawers are not designed with tolerances in the millimeter rangeThat surprises me a bit, because the drawers often seem very precisely assembled, but apparently accuracy within tenths of a millimeter is necessary to prevent jamming.
It would be interesting to know if the manufacturer provides official guidelines regarding tolerances or maintenance.
georgsin schrieb:
Are there any recommendations for suitable lubricants that won’t damage the tracks?Yes, definitely: Avoid using regular oil or grease – these tend to attract dust and become sticky quickly. Silicone sprays or special PTFE (Teflon) sprays designed for plastic and metal parts work best.
They provide smooth sliding without leaving residues.
Also, if you get the chance, you can remove the guide rails and clean them thoroughly – dust and lint often accumulate in places you don’t notice.
Drawer management is almost an art form, isn’t it? :-)
edisondan19 Feb 2022 09:45georgsin schrieb:
It would be interesting to know if there are official guidelines from the manufacturer regarding tolerances or maintenance.Unfortunately, IKEA usually does not provide very detailed technical information about tolerances. Maintenance instructions typically focus only on surface cleaning.
In practice, this means users need to rely on simple measures such as checking screws, cleaning the runners, and replacing them if necessary.
If sticking persists after these steps, replacing the sliding mechanism with higher-quality runners could be a worthwhile option—especially since the original slides are not designed for high loads or precision.
