ᐅ Why do MALM beds start squeaking after extended use?
Created on: 4 Mar 2020 09:17
Hannah56
I have a question that has been on my mind for some time: Why do MALM beds start squeaking after extended use?
Specifically, I mean the IKEA beds where, after a period of use, a noticeable squeaking noise occurs, especially when moving in the bed or turning over. I am interested in the exact causes of this—whether it is related to the materials, the construction, or the fastenings. It would also be helpful to know if there are common weak points responsible for this and whether the problem can be fixed with simple measures without having to take the entire bed apart.
Perhaps someone has experience with MALM beds or knows the technical reasons why squeaking might develop over time.
Bagupo
4 Mar 2020 14:29
Tighten screws, check wooden slats, and glue felt pads to friction points.
Use WD-40 sparingly and avoid direct contact with the surface of the membrane.
Garthre
5 Mar 2020 07:55
Squeaking often occurs due to loose or weakened fasteners combined with slight material movement.
For a long-lasting solution, I recommend:
- Systematically retightening screws, ideally using a torque wrench
- Cleaning contact points and, if necessary, cushioning them with Teflon tape or self-adhesive felt pads
- Avoiding oil-based lubricants on wood-like surfaces, as they can damage the material
This will help prevent friction noises over time and protect the material from damage.
lejesin
5 Mar 2020 09:18
Garthre schrieb:
Avoid using oil-based lubricants on wood-like surfaces, as they can damage the material\
This is an important point.
Alternatively, dry lubricants based on PTFE are recommended. They prevent contamination, provide good slip properties, and do not harm the material.
And yes, the typical weak points are the screw connections between the base, headboard and footboard, as well as the slatted frame attachment.
ralfsau
6 Mar 2020 08:02
The squeaking usually results from the interaction between fasteners and the wood-based materials.
Tightening screws, cushioning clamps (e.g., with felt), and if necessary, using PTFE spray are the most effective solutions.
