Lately, I have been experiencing an issue with my Billy shelves from Ikea that has been quite confusing: the wood starts to swell after some time, causing the shelves to no longer fit properly or even to warp slightly. Since Billy shelves are mainly made from coated particleboard or MDF, I wonder why exactly this swelling occurs.
Is this a common problem related to the choice of materials, or could external factors such as humidity, location, or assembly play a significant role? Are there any known causes or mechanical factors that could explain the swelling?
I look forward to well-informed explanations, as I actually find the shelf very practical, but this problem is quite frustrating.
Hey Jelakin!
It’s great that you’re looking so closely into the BILLY shelf! 🙂
The warping of the wood—or rather wood-based materials like chipboard—is usually related to moisture. These panels absorb water and then expand. This often happens in bathrooms or rooms with high humidity.
I experienced the same issue with my BILLY shelf and was advised not to place the shelves directly against damp walls and to ventilate the room regularly.
Keep at it; it will definitely work out!
REOHEINRIC18 Jul 2020 20:34bauku schrieb:
So, the swelling of wood—or more precisely wood-based materials like particleboard—is usually related to moisture.That’s exactly right. The BILLY shelves are made from wood-based materials like particleboard or MDF, which are protected against moisture by melamine or foil coatings, but these barriers are not completely impermeable.
If the surrounding humidity is high or there are significant temperature fluctuations, the material starts to absorb water. This causes swelling because wood-based materials are highly hygroscopic—they take up water, leading to changes in volume.
Another factor is the quality and workmanship of the coating. Exposed edges or damaged surfaces provide entry points for moisture.
Long-term storage of shelves in damp basements or placement in poorly ventilated bathrooms often leads to these issues.
REOHEINRIC schrieb:
The BILLY shelves are made from engineered wood products like particleboard or MDF, which are protected against moisture by melamine or foil coatings, but this barrier is not completely watertight.I still find it surprising how many people think this stuff is real “wood” and therefore expect the durability of solid wood. Honestly – BILLY shelves are an inexpensive piece of furniture made from particleboard with a laminated foil surface, not solid wood.
So why is anyone surprised when it swells due to moisture?
I think there is often a misunderstanding here because Ikea cleverly markets the design and name.
If that’s not acceptable, people should choose weather-resistant furniture made from real wood instead of experimenting with particleboard.
To clearly outline the cause of swelling in BILLY shelves:
1. Material: The shelves are mostly made from compressed wood fibers (particleboard, MDF). These materials absorb water.
2. Protective layer: Melamine films or coatings generally act as a barrier. This barrier is effective on flat surfaces but often less so on the edges.
3. Moisture absorption: Edges, scratches, or damaged areas allow water to penetrate.
4. External conditions: High humidity, temperature fluctuations, and contact with damp walls or floors promote swelling.
Practical advice:
- Avoid placing shelves directly against damp areas.
- Seal edges with special edge protection coatings or paint.
- Regularly ventilate the room to maintain consistent humidity levels.
Understanding these points helps to specifically prevent the causes.
Practical advice:
PAR63 schrieb:
Paint or coat edges with special edge protection.This is an important point. Currently, the edges of BILLY shelves are only covered with foil or paper wrapping, which do not provide a permanent moisture barrier.
Unlike solid wood, which allows some natural moisture regulation, these materials are not suitable for high humidity. Therefore, swelling is not a defect in the traditional sense but a result of the material properties.
Anyone who wants to extend the lifespan of their shelves should seal the edges and ensure a dry environment.
