ᐅ Who has tips for an affordable Ikea Metod kitchen remodel?
Created on: 13 May 2017 08:43
Flobenedik
I am currently planning a renovation of my Ikea Metod kitchen and am looking specifically for tips on how to carry out this project as cost-effectively as possible. I am particularly interested in experiences with affordable alternatives to standard parts or ways to sensibly integrate used components.
Also: What should definitely be considered during the dismantling and reassembly to avoid costly rework later on?
I appreciate any advice that focuses on budget-friendly solutions and smart approaches – including tips that might not be obvious. Thank you in advance!
Flobenedik14 May 2017 07:58LIELCHEN schrieb:
Why always Ikea? Metod is solid, but especially for affordable renovations, it’s definitely worth considering lesser-known brands or custom-made fronts.Thanks for the tip, LIELCHEN! I see it this way: The modularity of Metod and its standardized measurement system make it quite feasible for DIY builders to add their own touch.
That’s why I mainly wanted to keep the basic units and maybe save on fronts, handles, and the countertop. The option to integrate used modules sounds interesting—does anyone have specific experience or sources for that?
The goal isn’t to get a complete solution for cheap, but rather a smart combination of new and used parts while maintaining good quality.
Flobenedik schrieb:
The possibility of integrating used modules sounds interesting; does anyone have specific experience or sources?For used Ikea Metod modules, I recommend local classifieds platforms, flea markets, and specialized kitchen exchange sites. Important: Check the dimensions, condition of fittings, and any signs of wear carefully.
For cost-effective remodeling:
- Avoid oversized countertops that require extensive adjustment.
- Keep as many original mounting points as possible.
- Use smart corner solutions to maximize storage space.
This saves rework and extra expenses.
Flobenedik15 May 2017 09:22Gino38 schrieb:
Using Ikea’s planning software to avoid wrong purchasesThat’s true, Gino38. I’m currently making extensive use of Ikea’s kitchen planner software to clearly see exactly what I really need. This helps me avoid extra costs caused by wrong purchases.
Shawn38 schrieb:
For countertops, it’s worth considering affordable options with custom cuttingThat caught my attention, especially since the countertop might become my most expensive single item. How exactly did you handle it back then? Did you have it cut directly at a home improvement store, or did you cut it yourself? And which materials would you recommend in terms of price and durability?
I’m grateful for any additional advice here.
Flobenedik schrieb:
How exactly did you do it back then? Did you have it cut directly at a home improvement store or did you cut it yourself?I would definitely have a professional do it – at home improvement stores that offer cutting services.
This is often cheaper than buying the necessary tools yourself and risking mistakes.
And laminate boards are really durable; I can highly recommend them if you don’t want to pay the price for solid wood.
Flobenedik schrieb:
The countertop might also become the most expensive single item for meWell, the countertop is the crucial point. Especially in a budget renovation, the kitchen deserves special attention.
What I suggest, somewhat provocatively, is to dare to experiment with different materials.
Why not opt for solid wooden boards and oil them yourself? Or install ceramic tiles as a countertop surface? This can reduce costs, make the appearance more interesting, and give a higher-quality feel to the touch.
Of course, this involves a bit more manual work and planning, but it often pays off.
