ᐅ What types of screws are used with Ikea Hemnes furniture?
Created on: 24 Dec 2019 10:13
BURZIN
BURZIN
24 Dec 2019 10:13
Good morning everyone, I am currently about to assemble an Ikea Hemnes chest of drawers and want to make sure I have a clear overview of the screws needed. Therefore, my specific question to you is: What types of screws are typically used in the Ikea Hemnes furniture line, especially for the chest of drawers or desks? I am interested in the sizes, thread types, as well as any different screw heads that are used during assembly. This way, I can ensure that if I need to buy replacements or additional screws, I get the right ones immediately and avoid any delays in building. Thanks in advance for your well-informed answers!
pinJustin
24 Dec 2019 10:29
Hemnes usually includes cylindrical head screws with an internal hex drive in M6 size, mostly 30 to 40mm (1.2 to 1.6 inches) long. It also comes with some Phillips wood screws. The screws are typically either zinc-plated or black.
klo40
24 Dec 2019 11:02
A brief addition: Ikea Hemnes mainly uses cylinder head screws with internal hex drive (also known as Allen screws), with an M6 diameter. These screws are usually between 30mm and 50mm (1.2 inches and 2 inches) long, tailored to different furniture parts. It is also important to know that Hemnes often uses dowels and wooden dowels as additional connecting elements. Wood screws, on the other hand, are used specifically in joints that require higher tensile strength in the wood. When purchasing replacements, I recommend checking not only the type of screw but also the thread pitch; Ikea uses standard metric threads here, meaning regular M6 with a 1.0mm pitch.
KIN42
25 Dec 2019 08:46
It can be assumed that Ikea uses proven metric screw types for Hemnes, which are standardized and easy to replace. In addition to cylinder head screws with internal hex drives (Allen screws), Ikea also uses dowel screws in wood connectors and flat round screws for the back panels. Those who want to replace the screws should also pay attention to the steel hardness – Hemnes furniture often requires screws with a minimum strength class of 8.8. Using material that is too soft could cause long-term problems, such as issues when repeatedly retightening. Ideally, replacement parts are also available directly from Ikea customer service, where the screws are precisely matched and correspond to the original parts.
Jonna
26 Dec 2019 14:19
I would like to add to the list and organize it clearly: - Cylindrical head screws with internal hex drive, M6, lengths usually between 30 and 50 mm (1.2 and 2 inches), electro-galvanized or black. - Wood screws with Phillips head, approximately 4 mm to 5 mm (0.16 to 0.2 inch) in diameter, about 30 mm (1.2 inches) long, used for cross connections and back panels. - Hardwood dowels, round, about 8 mm (0.3 inch) in diameter, for positioning and stabilizing. - Set screws (sometimes without a head) that fit into metal fittings and allow precise adjustment. - Pan head screws for securing back panels firmly, usually with a Phillips head. For precise reorder, it is recommended to carefully consult the specific assembly instructions, as the Hemnes series does have a variety of options. In any case, the screws are standardized fasteners, which makes repurchasing easier.
BURZIN
27 Dec 2019 09:07
Jonna schrieb:
In any case, the screws are standardized components, which makes repurchasing easier.
Thank you for the information; this is exactly what I needed to know. Does anyone know if Ikea uses any special screw head types for Hemnes, or are all screws exclusively equipped with hexagonal socket heads? I ask because I want to adjust my cordless screwdriver bit collection and might need additional bits for screws with unusual heads.
