Hello everyone, I’m planning to assemble an IKEA Billy bookcase soon. I’m wondering which tools actually make the assembly easier or save time. IKEA usually only recommends the included Allen key, but I’ve heard that with a few additional tools, it can go much faster and be easier.
I’m interested in which tools you at least use when assembling Billy, and why. Could you also mention the advantages and disadvantages of each tool? For example, screwdrivers, cordless drills, hammers, or special aids. An overview with practical tips would be great. Especially if you want to build several shelves, I don’t want to waste time with tools that are too small or the wrong approach. Thanks in advance for all the tips!
The most important insight upfront: A good cordless drill driver is almost essential if you want to assemble multiple BILLY shelves.
The included Allen key is sufficient for individual small pieces of furniture, but with the scope of a BILLY shelf, you quickly realize that it becomes more of a hassle than a help.
A cordless drill driver with adjustable torque is recommended so that the screws are neither too tight nor do they damage the material. A bit set with appropriate Allen and Phillips bits completes the setup. For the wooden dowels, I prefer using a hammer with a plastic head to prevent damaging the surface.
Additionally, a small center punch can be helpful when pre-drilling if you want to drill very precise holes, but it is not mandatory.
Since I often assemble furniture myself, I’ve developed the habit of approaching the process in clear steps using the right tools. For the BILLY, a cordless drill with adjustable torque is very helpful.
A small tip: Insert all dowels first and make sure all parts fit together properly before tightening the screws. This helps prevent any stress or warping.
For the screws, I use hex keys (Allen wrenches) that either come with the cordless drill bit set or are included in a good screwdriver set. For the dowels, I use a rubber mallet to avoid damaging the side panels.
If you want to position the shelves, a spirit level is useful, and a pencil comes in handy for marking any holes to be drilled.
One more thing: If any screws get stuck, don’t force them; instead, adjust or reposition slightly. Good luck!
Hey everyone! I really love how much a simple cordless drill speeds up the assembly of BILLY! 🙂 Before, I always screwed in with the small Allen key – it was really frustrating!
I totally agree with that! Especially when you’re building three shelves at once like I did – it really saves hours!
For the dowels, I always use a small hammer to avoid hitting too hard, otherwise you get ugly dents!
Add a small spirit level and you get a really professional result. You feel great afterwards when everything fits and no shelves are crooked. So: cordless drill + rubber mallet is my tip for fast, clean BILLY assembly! :-)
Blavin schrieb:
A good cordless drill is almost essential
It’s interesting to see how many people here praise the cordless drill as a cure-all. Honest opinion: a cordless drill can save time, but many beginners apply too much torque and end up damaging the wood.
Obviously, the right torque is crucial. But a simple Allen key has the advantage of giving you better control over the screw and reducing the risk of applying too much force.
In general, I’m skeptical about using cordless drills for furniture like BILLY, which rests on broad surfaces but uses relatively small screws. You need a delicate touch; otherwise, the result can look sloppy.
taudi schrieb:
For the screws, I use Allen keys, which are either included in the cordless drill bit set or in a good screwdriver set.
