BENNETREO30 Jul 2015 09:17Hello everyone, I’m currently about to assemble a Billy bookshelf and am wondering which tools really make the process easier. IKEA includes a small hex key, but are additional tools like a cordless drill, rubber or wooden mallet, clamps, or special angle rulers helpful to build the shelf as quickly and sturdy as possible? Are there any useful tips or tools from practical experience to insert the dowels precisely or to align the carcasses properly? I want to avoid the shelf wobbling afterward or making the assembly unnecessarily complicated. Looking forward to your advice!
Regarding your question about tools that make assembling a BILLY bookshelf easier: I recommend a cordless drill with adjustable torque settings to avoid overtightening screws and damaging the particleboard. This control is especially helpful when inserting cam connectors. A small spirit level or angle finder ensures the shelf stands properly, which is important if you plan to place multiple units side by side.
For positioning the dowels: a simple hole locator or centering tool can help you hit the exact center on the boards. This reduces misaligned joints. Additionally, you can use a clamp to temporarily hold the parts together while connecting them, preventing any slipping.
A common cause of errors is not drilling the holes precisely or tightening the screws too quickly, which can cause the boards to split. Patience pays off. To summarize, I recommend:
- Cordless drill with adjustable torque
- Spirit level/angle finder
- Rubber mallet
- Clamp
- If needed, hole centering tool
I hope this helps!
- Rubber mallet
- Clamp
I hope this helps!
Sepele schrieb:
A cordless drill/driver with torque control, so you don’t overtighten the screws and damage the particleboard. This is an essential tip. In addition, I recommend checking the supplied screws and wall plugs for completeness and any damage before assembly.
Furthermore, a combination of a spirit level and a protractor has proven useful for aligning the shelves and side panels. This allows for precise inspection and adjustment of the shelving unit’s assembly.
It should also be noted that a rubber mallet is ideal for fitting joints together without damaging the usually coated surfaces. A wooden mallet or metal hammer can easily leave marks.
For drill holes, sometimes a simple drill bit sized for wood helps to pre-drill the workpieces if the pre-made holes don’t provide enough guidance, especially during corrections. Overall, I recommend:
- Cordless drill/driver with torque control
- Spirit level + protractor
- Rubber mallet
- Inspection of supplied materials
- Hand drill or cordless drill for corrections
These tools ensure a precise and stable assembly of the BILLY shelving unit.
I have to say, alongside the tools already mentioned, a good dose of patience and a bit of music really make the assembly much easier 🙂
But seriously, a small tip from my own experience: when using a cordless drill on metal connectors, set it to a low speed and apply gentle pressure. Nothing is worse than going too fast—you end up overtightening the screws, which causes everything to jam or break.
Oh, and if you stick some felt tape or a small piece of foam rubber between the wall and the shelf, it can help dampen any vibrations in case it wobbles.
So, a rubber mallet and a torque screwdriver make the perfect combo—and have fun putting it all together! :-)
BENNETREO schrieb:
I want to avoid the shelf wobbling afterwards or the assembly becoming unnecessarily complicated. This is also my main concern when assembling furniture. I have always found it helpful to lay out the shelf parts next to each other and loosely fit the connectors together before actually joining them. This way, you can immediately see if something is misaligned or if pressure points occur.
Additionally, a small tip: work at a large, well-lit, and level workspace. This helps prevent mistakes and back pain.
Besides a rubber mallet and cordless drill, I have occasionally found small clamps very useful to hold the parts in place during screwing. This keeps everything from slipping and makes fitting the parts together easier.
So: preparation, calmness during assembly, and the right tools are, in my opinion, the best combination. I hope this helps you a bit!
